Toolchain Install: No module named 'em'
Hi - I’m trying to set up the toolchain on a new (M3) MacBook running Sonoma.
I’ve followed the Mac instructions and run into this error when trying to compile:
On typing: make px4_sitl gazebo-classic
I get:
Failed to import em: No module named ‘em’
You may need to install it using:
pip3 install --user empy
I try and install empy and get ‘Requirement already satisfied’. Have tried PIP uninstall and reinstall: same issue. Have also tried some of the solutions for similar issues in the forum - but sudo solution doesn’t work for me.
Can anyone help?
John
Maybe a version greater than a particular version is required.
Thanks Abhishek - which tool are you suggesting to upgrade?
It’s a new Mac so everything is a clean install and should be relatively current.
I’m using:
  • pip3 21.2.4
  • Python 3.9.6
Lastest version of the MacOs documentation
check empy version
is it 3.3.4
Thanks Abhishek - appreciate your help. empy version is 4.2 - not sure if I need to downgrade?
Am new to PX4 development - wondered if the compiler error ‘Failed to import em: No module named ‘em’’ error message was some sort of path issue somewhere?
Px4 requires the version i mentioned.
use : pip install empy==3.3.4
Note : dont use sudo…
To know if this is a path error maybe
Try manual importing em in python shell.
You can find required versions in requirements.txt
Thanks Abhishek - I see empy must be equal to that version - not sure how it went wrong as I followed the MacOs instructions.
I’ll have a play to downgrade that component and see if it works.
Really appreciate the help
John.
Am now on empy 3.3.4 however still getting an ‘Failed to import em: No module named ‘em’ error :frowning:
Will research manual importing in python shell - little new to this coming from an IOS dev background.
Further investigation - looks like the standard install has left me with 2 version of Python - v3.9.6 and v3.12
Am trying to use venv to manage access to right packages - not go there yet.
I can’t see the right version of python in the requirement.txt file - any recommendation before I try to uninstall one?
i am using Python 3.10.12 and it works fine.
Thanks Abhishek - I think the main setup and therefore the default instructions end up with 2 versions of python installed 3.9 and 3.12.
I cleared my .venv and set it up from scratch with a single python version (3.12) - seemed to clear the import not found error - which is a step forward.
Still not building cleanly but I’ll investigate that separately.
Really appreciate your help
