Hi everyone, I am new to PX4 development and eager to learn. However, I am unable to install and run PX4 using the online tutorial on my MBP 2016 running OSX 10.15.1 (latest Catalina). After installing all the libraries and required toolchains, I get this error when trying to build the code using make px4_sitl gazebo:
python import error: No module named em
Required python packages not installed.
On a Debian/Ubuntu system please run:
sudo apt-get install python-empy
sudo pip install catkin_pkg
On MacOS please run:
sudo pip install empy catkin_pkg
On Windows please run:
easy_install empy catkin_pkg
[10/731] Building CXX object src/lib/DriverFramework/framework/src/CMakeFiles/df_driver_framework.dir/WorkItems.cpp.o
make: *** [px4_sitl] Error 1
The problem is I already have these packages installed. If I run sudo pip install empy catkin_pkg I get the following:
Requirement already satisfied: empy in /Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages (3.3.4)
Requirement already satisfied: catkin_pkg in /Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages (0.4.14)
Requirement already satisfied: docutils in /Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages (from catkin_pkg) (0.15.2)
Requirement already satisfied: pyparsing in /Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages (from catkin_pkg) (2.4.2)
Requirement already satisfied: python-dateutil in /Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages (from catkin_pkg) (2.8.0)
Requirement already satisfied: six>=1.5 in /Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages (from python-dateutil->catkin_pkg) (1.12.0)
I have experienced this error with yaml as well even though pyyaml is also installed.
Is there any way to fix this error?
