Hello, dear community. Perhaps this is not the correct place to ask but I need help.
Thank you
Required Info about Realsense camera
Camera Model
T265
Firmware Version
0.2.0.951
Operating System & Version
Linux (Ubuntu 18)
Kernel Version (Linux Only)
4.9.201
Platform
NVIDIA Jetson
SDK Version
{ legacy / 2.49.0 }
Language
python
Segment
Drone
Issue Description
Dear community.
I have built a drone for research purposes by using pixhawk, Jetson TX2, and T265 Realsense.
T265 Camera is facing forward.
I have been holding several tests indoors and its performance is good enough. But when I do the test outdoors the drone goes up losing its control. Below is the workflow of the drone.
Setmode to Offboard
Arm the vehicle
Takeoff to the target position Z= 1.5m
Hold the position until the flight mode be equal to “land.mode” by pressing the “y” key
The above workflow works perfectly in indoor tests but outdoors it does not work, three days ago with the sun shining and the drone looking on the opposite side to the sun, so the drone takeoff and thanks to the thread linking the landing pad with the drone, the drone did not go up more than 3 meters.
Is there any suggestion on how to solve this issue?
Any help is appreciated.
Thank you so much
Hi @pedro thank you for your answer. What kind of log you need?
I am using ROS melodic, mavros, auterion bridge for t265 and ros.
The maximum altitude was set to 1.5meter and the cable is 2 meters.
I am sorry for my late reply. Here is the PX4 log.
I don’t know what kind of rosbag I should show you because ROS is working quite well, but the camera values are as shown below. As I said, the maximum altitude must be 1.5 meters
