I installed the latest v1.11.3 via QGC v4.1.2 in a Pixhawk 1 with updated bootloader so the Firmware Upgrade installs px4fmu-v3_default.px4. After the reboot, it doesnât show it saved it so the Airframe tab in QGC is Red and it wonât let it go any further. But Generic Quadplane VTOL Tiltrotor doesnât show as an option.
This just came up but if I reboot, it goes back to asking Airframe setup. Is this normal? In other words, every time I connect it QGC, I have to change SYS_AUTOSTART then continue from there?
Bro i have a problem like you. I have a pixhawk as you. It is my error. Also each start of program i see this parameter is red. Maybe it isnt normal. Also can you see my problem? "calibration failed: reading sensor" I get this error
