Some questions about “mc_att_control” hope to get help
void
MulticopterAttitudeControl::control_attitude(float dt)
vehicle_attitude_setpoint_poll();
_thrust_sp = _v_att_sp.thrust;
/* construct attitude setpoint rotation matrix */
math::Quaternion q_sp(_v_att_sp.q_d[0], _v_att_sp.q_d[1], _v_att_sp.q_d[2], _v_att_sp.q_d[3]);
math::Matrix<3, 3> R_sp = q_sp.to_dcm();
/* get current rotation matrix from control state quaternions */
math::Quaternion q_att(_ctrl_state.q[0], _ctrl_state.q[1], _ctrl_state.q[2], _ctrl_state.q[3]);
math::Matrix<3, 3> R = q_att.to_dcm();
/* all input data is ready, run controller itself */
/* try to move thrust vector shortest way, because yaw response is slower than roll/pitch */
math::Vector<3> R_z(R(0, 2), R(1, 2), R(2, 2));
math::Vector<3> R_sp_z(R_sp(0, 2), R_sp(1, 2), R_sp(2, 2));
/* axis and sin(angle) of desired rotation */
math::Vector<3> e_R = R.transposed() * (R_z % R_sp_z);
/* calculate angle error */
float e_R_z_sin = e_R.length();
float e_R_z_cos = R_z * R_sp_z;
1、The weight of yaw why is that so
/* calculate weight for yaw control /
float yaw_w = R_sp(2, 2) * R_sp(2, 2);
calculate rotation matrix after roll/pitch only rotation */
math::Matrix<3, 3> R_rp;
if (e_R_z_sin > 0.0f) {
/* get axis-angle representation */
float e_R_z_angle = atan2f(e_R_z_sin, e_R_z_cos);
math::Vector<3> e_R_z_axis = e_R / e_R_z_sin;
2、Why can the error be expressed as such?Can yaw error can be directly modified “e_R(2)”
     e_R = e_R_z_axis * e_R_z_angle;//Why can the error be expressed as such?Can yaw error can be directly modified “e_R(2)”
/* cross product matrix for e_R_axis */
math::Matrix<3, 3> e_R_cp;
e_R_cp.zero();
e_R_cp(0, 1) = -e_R_z_axis(2);
e_R_cp(0, 2) = e_R_z_axis(1);
e_R_cp(1, 0) = e_R_z_axis(2);
e_R_cp(1, 2) = -e_R_z_axis(0);
e_R_cp(2, 0) = -e_R_z_axis(1);
e_R_cp(2, 1) = e_R_z_axis(0);
/* rotation matrix for roll/pitch only rotation */
R_rp = R * (_I + e_R_cp * e_R_z_sin + e_R_cp * e_R_cp * (1.0f - e_R_z_cos));
} else {
/* zero roll/pitch rotation */
R_rp = R;
/* R_rp and R_sp has the same Z axis, calculate yaw error */
math::Vector<3> R_sp_x(R_sp(0, 0), R_sp(1, 0), R_sp(2, 0));
math::Vector<3> R_rp_x(R_rp(0, 0), R_rp(1, 0), R_rp(2, 0));
e_R(2) = atan2f((R_rp_x % R_sp_x) * R_sp_z, R_rp_x * R_sp_x) * yaw_w;
3、for large thrust vector rotations how to calculate???Is it convenient to provide some documentation?
if (e_R_z_cos < 0.0f) {
/* for large thrust vector rotations use another rotation method:
* calculate angle and axis for R → R_sp rotation directly */
math::Quaternion q_error;
q_error.from_dcm(R.transposed() * R_sp);
math::Vector<3> e_R_d = q_error(0) >= 0.0f ? q_error.imag() * 2.0f : -q_error.imag() * 2.0f;
/* use fusion of Z axis based rotation and direct rotation */
float direct_w = e_R_z_cos * e_R_z_cos * yaw_w;
e_R = e_R * (1.0f - direct_w) + e_R_d * direct_w;
/* calculate angular rates setpoint */
_rates_sp = _params.att_p.emult(e_R);
thanks,Looking forward to receiving your reply。
Did you check the paper mentioned in the header?
Publication for the desired attitude tracking:
Daniel Mellinger and Vijay Kumar. Minimum Snap Trajectory Generation and Control for Quadrotors.
Int. Conf. on Robotics and Automation, Shanghai, China, May 2011.
