Is it possible to use the solo transmitter with PX4 on a pixhawk. I would like to do this so I can use QGC on iOS since there is not a supported idevice 915mhz radio or is there any other wifi options that can give a minimum of 800m range?
As far as I know, not without a Solo on the other end. You need their companion computer setup to make it work I would think.
