SITL/Gazebo offboard control with attitude and throttle
I’m trying to fly a quadcopter in a circle using offboard control and MAVSDK. I want to use the Attitude and Throttle commands.
To do this, I calculate the desired centripetal acceleration from which I extract the pitch and roll angles. I set the yaw so that it is aligned with the velocity vector (tangential).
I estimated the hover acceleration by performing simulation experiments.
Unfortunately, I’m not getting the expected results at all when I simply integrate the desired acceleration and not use PX4.
Can you help me?
Thank you
import numpy as np
import time
import asyncio
from mavsdk import System
from mavsdk.offboard import OffboardError, VelocityNedYaw, Attitude
import matplotlib
matplotlib.use("TkAgg")
import matplotlib.pyplot as plt
DESIRED_SPEED = 1.0
CENTRIPETAL_ACCEL = 0.5
HOVER_THROTTLE = 0.728
positions = []
positions_theo = []
accel_cmds = []
def compute_euler_angles_from_acceleration(yaw_deg, ned_accel):
    g = np.array([0.0, 0.0, 9.81])
    a = g - ned_accel
    pitch = -np.arcsin(a[0]/np.linalg.norm(a))
    roll = np.arctan2(a[1], a[2])
    return (np.degrees(roll), np.degrees(pitch), yaw_deg)
async def run():
    drone = System(port=50051)
    await drone.connect(system_address=f"udpin://0.0.0.0:14540")
    async for state in drone.core.connection_state():
        if state.is_connected:
            break
    async for health in drone.telemetry.health():
        if health.is_global_position_ok and health.is_home_position_ok:
            break
    await drone.action.arm()
    await drone.action.takeoff()
    await asyncio.sleep(10)
    await drone.offboard.set_velocity_ned(VelocityNedYaw(0.0, 0.0, 0.0, 0.0))
    try:
        await drone.offboard.start()
    except OffboardError:
        return
    await drone.offboard.set_velocity_ned(VelocityNedYaw(DESIRED_SPEED, 0.0, 0.0, 0.0))
    t = 0.0
    dt = 0.005
    yaw = 0.0
    yaw_rate = CENTRIPETAL_ACCEL / DESIRED_SPEED
    pos_theo = [0, 0, 1.5]
    vel_theo = np.array([DESIRED_SPEED, 0.0, 0.0])
    T = time.time()
    while t < 6.0:
        accel_dir = np.array([-np.sin(yaw), np.cos(yaw), 0.0])
        accel_cmd = CENTRIPETAL_ACCEL * accel_dir + np.array([0, 0, -9.81])
        accel_cmds.append(accel_dir)
        roll_deg, pitch_deg, yaw_deg = compute_euler_angles_from_acceleration(yaw_deg=np.degrees(yaw), ned_accel=accel_cmd)
        throttle = (HOVER_THROTTLE * 1.0) / (np.cos(np.radians(roll_deg)) * np.cos(np.radians(pitch_deg)))
        pv = await drone.telemetry.position_velocity_ned().__anext__()
        positions.append(np.array([pv.position.north_m, pv.position.east_m, pv.position.down_m]))
        vel_theo += CENTRIPETAL_ACCEL * accel_dir  * dt
        pos_theo += vel_theo * dt
        positions_theo.append(pos_theo.copy())
        await drone.offboard.set_attitude(Attitude(roll_deg=roll_deg, pitch_deg=pitch_deg, yaw_deg=yaw_deg, thrust_value=throttle))
        await asyncio.sleep(0)
        yaw += yaw_rate * dt
        t += dt
        print(time.time() - T)
        T = time.time()
    try:
        await drone.offboard.stop()
        return
    await drone.action.land()
if __name__ == "__main__":
    asyncio.run(run())
    def ned_to_enu(NED):
        ENU = np.zeros_like(NED)
        ENU[:, 0] = NED[:, 1]
        ENU[:, 1] = NED[:, 0]
        ENU[:, 2] = -NED[:, 2]
        return ENU
    positions = ned_to_enu(np.array(positions))
    positions_theo = ned_to_enu(np.array(positions_theo))
    accel_cmds = ned_to_enu(np.array(accel_cmds))
    fig = plt.figure()
    ax = fig.add_subplot(111, projection="3d")
    ax.plot(
        positions[:, 0], positions[:, 1], positions[:, 2], linewidth=2,
        label="actual traj"
    ax.plot(
        positions_theo[:, 0], positions_theo[:, 1], positions_theo[:, 2], "--", linewidth=3,
        label="theoretical traj"
    ax.quiver(
        accel_cmds[:, 0], accel_cmds[:, 1], accel_cmds[:, 2],
        length=1.0, normalize=True,
        color="red", alpha=0.8, label="commanded accel"
    ax.legend()
    def set_axes_equal(ax):
        x_limits = ax.get_xlim3d()
        y_limits = ax.get_ylim3d()
        z_limits = ax.get_zlim3d()
        x_range = abs(x_limits[1] - x_limits[0])
        y_range = abs(y_limits[1] - y_limits[0])
        z_range = abs(z_limits[1] - z_limits[0])
        max_range = max(x_range, y_range, z_range)
        x_middle = sum(x_limits) / 2
        y_middle = sum(y_limits) / 2
        z_middle = sum(z_limits) / 2
        ax.set_xlim3d([x_middle - max_range/2, x_middle + max_range/2])
        ax.set_ylim3d([y_middle - max_range/2, y_middle + max_range/2])
        ax.set_zlim3d([z_middle - max_range/2, z_middle + max_range/2])
    set_axes_equal(ax)
    plt.show()
It sounds like you’re doing open loop control but you would get better results if you close the loop by adjusting your inputs based on where you are at a given moment minus the setpoint.
