Hi everyone! ![]()
I have a question regarding SITL in Gazebo without using GPS. I managed to run the iris_optical_flow model with no problem using these steps:
- Find iris model in /Path to PX4-Autopilot/Tools/simulation/gazebo-classic/sitl_gazebo-classic/models/ folder.
- Open iris.sdf with VS Code.
- Comment out these lines of code:
<!--include>
<uri>model://gps</uri>
<pose>0.05 0 0.04 0 0 0</pose>
<name>gps0</name>
</include>
<joint name='gps0_joint' type='fixed'>
<child>gps0::link</child>
<parent>base_link</parent>
</joint-->
- Comment out this code line in PX4-Autopilot/src/modules/simulation/simulator_mavlink/SimulatorMavlink.cpp file
_sensor_gps_pubs[i]->publish(gps);
After this I tried running iris_depth_camera drone the same way and with all of the additional steps needed to add this model to be able to run with make command but I get this error:
WARN [health_and_arming_checks] Preflight Fail: ekf2 missing data
pxh> [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
pxh> commander takeoff
pxh> INFO [tone_alarm] notify negative
I guess I have to configure some parameters on which pre-flight checks depend. I am doing this because I am trying to fly a drone using only IMU, Barometer, Magnetometer and Time of Flight camera.
Thank you all in advance ![]()
