OS: Ubuntu 18.04
So it’s been a few months since I’ve run simulation and I am now finding neither jmavsim nor gazebo work. They had both worked in the past, so I’m not sure what changed. Any input would be very much appreciated.
jmavsim
BUILD SUCCESSFUL
Total time: 0 seconds
Options parsed, starting Sim.
Starting GUI...
3D [dev] 1.6.0-pre12-daily-experimental daily
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (rsrc:j3dcore.jar) to method sun.awt.AppContext.getAppContext()
WARNING: Please consider reporting this to the maintainers of javax.media.j3d.JoglPipeline
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Inconsistency detected by ld.so: dl-lookup.c: 111: check_match: Assertion `version->filename == NULL || ! _dl_name_match_p (version->filename, map)' failed!
gazebo
-- Found GStreamer: adding gst_camera_plugin
-- Found GStreamer: adding gst_video_stream_widget
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
GSTREAMER_LIBRARIES (ADVANCED)
linked by target "gazebo_vision_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_uuv_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_lidar_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_geotagged_images_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_controller_interface" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "sensor_msgs" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_sonar_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_opticalflow_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "std_msgs" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_imu_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_opticalflow_mockup_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "mav_msgs" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "nav_msgs" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_wind_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "physics_msgs" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_gimbal_controller_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_mavlink_interface" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_motor_model" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_catapult_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_multirotor_base_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_magnetometer_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_usv_dynamics_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_barometer_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_parachute_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_gst_camera_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_irlock_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_gps_plugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "gazebo_video_stream_widget" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
linked by target "LiftDragPlugin" in directory /home/jake/code/jake/px4/Firmware/Tools/sitl_gazebo
See also "/home/jake/code/jake/px4/Firmware/build/px4_sitl_default/build_gazebo/CMakeFiles/CMakeOutput.log".
See also "/home/jake/code/jake/px4/Firmware/build/px4_sitl_default/build_gazebo/CMakeFiles/CMakeError.log".
FAILED: external/Stamp/sitl_gazebo/sitl_gazebo-configure
