SIH with custom airframe
Hi px4 community, I am trying to test out a custom tricopter airframe. I would like to make use of the SIH Module so I’m trying to set it up for the default tricopter as a start.
I am trying to modify the src/lib/modules/sih.cpp file. There is a section which generates the torques and thrusts, and I have confirmed from @Romain_Chiappinelli that this is the section I need to modify.
Also, I have created a new airframe config for the sih which points to the default tri mixer, rather than the quad_x one. I simply duplicated the config file here PX4-Autopilot/ROMFS/px4fmu_common/init.d/airframes/1100_rc_quad_x_sih.hil at main · PX4/PX4-Autopilot · GitHub
Now my question is: for a tricopter, with 3 rotors and 1 servo, looking at the sih.cpp file, I suppose u1,u2,u3 would refer to the motors, and u4 would refer to the tail servo?
@Romain_Chiappinelli or any one, Please help.
Thank you
Hi Daniel,
You can set your custom forces in Sih::generate_force_and_torques().
As for the mixer tri_y_yaw+, yes the motors are u1 u2 u3 and the servo is u4.
Be careful, u4 should be in the range [-1;1], you may want to modify Sih::read_motors() to include something like this.
Best,
Romain
HI @Romain_Chiappinelli , thanks once a gain for your response. Firstly, I’m a total beginner with c++. However, I can program in matlab and a bit in python so I have tried to joggle a few things as follows:
  • I added a new parameter SIH_L_ARM in the src/modules/sih/sih_params.c file, this is because the tricopter has three different lengths, one corresponding to the roll, two separate ones which relate to pitch, where I have assumed the one between the two front rotors and CG along x-direction to be L_pitch and then the new length I defined is the one between the tail rotor and the CG along the x-direction, which is the length of each arm in essence.
  • Added new default values for L_ROLL and L_PITCH.
  • Modified the sih_parameters_updated() function to include the newly added parameter.
  • Changed the model to that representing a tricopter
A snap shot of all these is below:
void Sih::parameters_updated()
_T_MAX = _sih_t_max.get();
_Q_MAX = _sih_q_max.get();
_L_ROLL = _sih_l_roll.get();
_L_PITCH = _sih_l_pitch.get();
_L_ARM = _sih_l_arm.get();
_KDV = _sih_kdv.get();
_KDW = _sih_kdw.get();
_H0 = _sih_h0.get();
void Sih::read_motors()
actuator_outputs_s actuators_out;
if (_actuator_out_sub.update(&actuators_out)) {
	for (int i = 0; i < NB_MOTORS; i++) { // saturate the motor signals
			if (i < NB_MOTORS) {
				float u_sp = constrain((actuators_out.output[i] - PWM_DEFAULT_MIN) / (PWM_DEFAULT_MAX - PWM_DEFAULT_MIN), 0.0f, 1.0f);
			} else {
				float u_sp = constrain((actuators_out.output[i] - PWM_DEFAULT_MIN) / ((PWM_DEFAULT_MAX - PWM_DEFAULT_MIN), -1.0f, 1.0f);
		_u[i] = _u[i] + _dt / _T_TAU * (u_sp - _u[i]); // first order transfer function with time constant tau
Please see if the read_motors() one makes sense as per limiting the servo to {-1,1}.
void Sih::generate_force_and_torques()
_T_B = Vector3f(0.0f, 0.0f, -_T_MAX * (+_u[0] + _u[1] + _u[2] * cos(_u[3])));
_Mt_B = Vector3f(_L_ROLL * _T_MAX * (-_u[0] + _u[1]),
_L_PITCH * _T_MAX * (+_u[0] + _u[1]) - (_L_ARM * _T_MAX * (_u[2] * cos(_u[3]))) - (_Q_MAX * (_u[2] * sin(_u[3]))),
_Q_MAX * (-_u[0] - _u[1] - _u[2] * cos(_u[3])) + (_L_ARM * _T_MAX * (_u[2] * sin(_u[3])));
The corresponding equations are:
Screenshot from 2021-03-26 17-40-10 Screenshot from 2021-03-26 17-40-30
So Ti = kt x omega_i^2, and Qi = kq x omega_i^2, where i = 1,2,3. Note I ignored Fy.
You can view it better on my fork here: https://github.com/DanAbara/PX4-Autopilot/blob/sih_tri/src/modules/sih/sih.cpp
and here https://github.com/DanAbara/PX4-Autopilot/blob/sih_tri/src/modules/sih/sih_params.c
Thanks a million in advance.
Best wishes,
Danielx
