Send trajectory in Offboard mode
Hi, I want to send a trajectory for the drone to follow.
Here is my code:
#! /usr/bin/env python3
import rospy
import math
from geometry_msgs.msg import PoseStamped
from mavros_msgs.msg import State, Trajectory
from mavros_msgs.srv import CommandBool, CommandBoolRequest, SetMode, SetModeRequest
current_state = State()
def state_cb(msg):
    global current_state
    current_state = msg
def fillUnusedTrajectorySetpoints(point):
    point.position.x = math.nan
    point.position.y = math.nan
    point.position.z = math.nan
    point.velocity.x = math.nan
    point.velocity.y = math.nan
    point.velocity.z = math.nan
    point.acceleration_or_force.x = math.nan;
    point.acceleration_or_force.y = math.nan;
    point.acceleration_or_force.z = math.nan;
    point.yaw = math.nan;
    point.yaw_rate = math.nan;
    return point
if __name__ == "__main__":
    rospy.init_node("offb_node_py")
    state_sub = rospy.Subscriber("mavros/state", State, callback = state_cb)
    local_pos_pub = rospy.Publisher("mavros/setpoint_position/local", PoseStamped, queue_size=10)
    traj_pub = rospy.Publisher("mavros/trajectory/generated", Trajectory, queue_size=10)
    rospy.wait_for_service("/mavros/cmd/arming")
    arming_client = rospy.ServiceProxy("mavros/cmd/arming", CommandBool)
    rospy.wait_for_service("/mavros/set_mode")
    set_mode_client = rospy.ServiceProxy("mavros/set_mode", SetMode)
    # Setpoint publishing MUST be faster than 2Hz
    rate = rospy.Rate(20)
    # Wait for Flight Controller connection
    while(not rospy.is_shutdown() and not current_state.connected):
        rate.sleep()
    pose = PoseStamped()
    pose.pose.position.x = 5
    pose.pose.position.y = 5
    pose.pose.position.z = 10
    setpoint = Trajectory()
    setpoint.header.stamp = rospy.Time.now()
    setpoint.header.frame_id = "local_origin"
    setpoint.type = 0
    setpoint.point_1.position.x = 5
    setpoint.point_1.position.y = 5
    setpoint.point_1.position.z = 10
    setpoint.point_1.velocity.x = math.nan
    setpoint.point_1.velocity.y = math.nan
    setpoint.point_1.velocity.z = math.nan
    setpoint.point_1.acceleration_or_force.x = math.nan
    setpoint.point_1.acceleration_or_force.y = math.nan
    setpoint.point_1.acceleration_or_force.z = math.nan
    setpoint.point_1.yaw = math.nan
    setpoint.point_1.yaw_rate = math.nan
    setpoint.point_2.position.x = -5
    setpoint.point_2.position.y = -5
    setpoint.point_2.position.z = 5
    setpoint.point_2.velocity.x = math.nan
    setpoint.point_2.velocity.y = math.nan
    setpoint.point_2.velocity.z = math.nan
    setpoint.point_2.acceleration_or_force.x = math.nan
    setpoint.point_2.acceleration_or_force.y = math.nan
    setpoint.point_2.acceleration_or_force.z = math.nan
    setpoint.point_2.yaw = math.nan
    setpoint.point_2.yaw_rate = math.nan
    # fillUnusedTrajectorySetpoints(setpoint.point_2)
    fillUnusedTrajectorySetpoints(setpoint.point_3)
    fillUnusedTrajectorySetpoints(setpoint.point_4)
    fillUnusedTrajectorySetpoints(setpoint.point_5)
    setpoint.time_horizon = [math.nan, math.nan, math.nan, math.nan, math.nan]
    setpoint.point_valid = [1, 1, 0, 0, 0]
    # Send a few setpoints before starting
    for i in range(100):
        if(rospy.is_shutdown()):
            break
        traj_pub.publish(setpoint)
        local_pos_pub.publish(pose)
        rate.sleep()
    offb_set_mode = SetModeRequest()
    offb_set_mode.custom_mode = 'OFFBOARD'
    arm_cmd = CommandBoolRequest()
    arm_cmd.value = True
    last_req = rospy.Time.now()
    while(not rospy.is_shutdown()):
        if(current_state.mode != "OFFBOARD" and (rospy.Time.now() - last_req) > rospy.Duration(5.0)):
            if(set_mode_client.call(offb_set_mode).mode_sent == True):
                rospy.loginfo("OFFBOARD enabled")
        else:
            if(not current_state.armed and (rospy.Time.now() - last_req) > rospy.Duration(5.0)):
                if(arming_client.call(arm_cmd).success == True):
                    rospy.loginfo("Vehicle armed")
        # local_pos_pub.publish(pose)
        rate.sleep()
But PX4 not allow me to arm. How can i send trajectory to drone?
Thank you.
I still researching running offboard mode using a published trajectory, but:
If you want more information, I recommend you open up QGroundControl and see if any error msgs pop up which may inform you on how to resolve it.
Also I believe the /mavros/trajectory/generated topic is for use in MISSION mode, not OFFBOARD mode, if you want to follow a trajectory in OFFBOARD mode, you will probably want to use the setpoint_trajectory mavros plugin.
I wouldnt use mavros. I would use the ROS2 bridge for PX4 here: ROS 2 User Guide | PX4 Guide (main)
