Hi!
I have mavros running on a Jetson NX companion computer. Mavros is connected to a pixracer running ardupilot via serial. The pixracer is connected to a simpleBGC gimbal via serial and communicating with it over mavlink.
I would like to send mavlink messages spesifically targeting the gimbal component, as the gimbal does not support broadcasted messages. For example mav_cmd_set_message_interval
As I have researched, I can’t see how I can change the target_compid
which mavros operates with. As such, I tried to make a mavros plugin and sending raw mavlink messages with UAS_FCU(m_uas)->send_message_ignore_drop();
, where I am able to specify target_sysid
and target_compid
. However, this does not work either.
So I was wondering if this is even possible? Maybe I have overlooked something which is obvious to an experienced mavros developer?
