I’m running a multicopter simulation as SITL using MAVSDK and Gazebo. For each copter, I launch a separate instance of a software which connects to the copter via UDP port 14540 + i. Everything is working fine, until I want to increase the number of copters further than 10. Following the manual, the maximum port is 14549 and each additional copter will be bound to this port. While this would be working fine, if I have one running connection to control multiple copters, this seems to be an issue if I have a single UDP-connection for each copter. As soon as I’m trying to connect the second copter to the UDP port 14549, I get an error message stating that the Port is already in use, which of course is correct.
Is there a way to change the default udp port so that I have more available ports? Maybe something like 16000 upwards?
I would appreciate any help.
Best,
Daniel
