ROS error running on ubuntu 16.04.
make px4_sitl_default gazebo works fine.
I am searching for this error for two days cant find the solution. Any help would be appreciated.
Terminal Output:
yuwenbin@yuwenbin-laptop:/home/nouman/Gazebo/Firmware$ roslaunch gazebo_ros empty_world.launch
… logging to /home/yuwenbin/.ros/log/f31b22ec-f597-11e9-b050-00215c20ee14/roslaunch-yuwenbin-laptop-5129.log
Checking log directory for disk usage. This may take awhile.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://yuwenbin-laptop:34701/
SUMMARY
PARAMETERS
- /rosdistro: kinetic
- /rosversion: 1.12.14
- /use_sim_time: True
NODES
gazebo (gazebo_ros/gzserver)
gazebo_gui (gazebo_ros/gzclient)
auto-starting new master
process[master]: started with pid [5139]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to f31b22ec-f597-11e9-b050-00215c20ee14
process[rosout-1]: started with pid [5152]
process[gazebo-2]: started with pid [5158]
process[gazebo_gui-3]: started with pid [5168]
terminate called after throwing an instance of ‘boost::filesystem::filesystem_error’
what(): boost::filesystem::status: Permission denied: “/home/yuwenbin/.gazebo/client-11345”
what(): boost::filesystem::status: Permission denied: “/home/yuwenbin/.gazebo/server-11345”
Aborted (core dumped)
[gazebo-2] process has died [pid 5158, exit code 134, cmd /opt/ros/kinetic/lib/gazebo_ros/gzserver -e ode worlds/empty.world __name:=gazebo __log:=/home/yuwenbin/.ros/log/f31b22ec-f597-11e9-b050-00215c20ee14/gazebo-2.log].
log file: /home/yuwenbin/.ros/log/f31b22ec-f597-11e9-b050-00215c20ee14/gazebo-2*.log
[gazebo_gui-3] process has died [pid 5168, exit code 134, cmd /opt/ros/kinetic/lib/gazebo_ros/gzclient __name:=gazebo_gui __log:=/home/yuwenbin/.ros/log/f31b22ec-f597-11e9-b050-00215c20ee14/gazebo_gui-3.log].
log file: /home/yuwenbin/.ros/log/f31b22ec-f597-11e9-b050-00215c20ee14/gazebo_gui-3*.log
