Report an error when rotorcraft flys:[ WARN] : PositionTargetGlobal failed because no origin
I’m puzzled because when I use offboard_node to make the rotorcraft fly, this WARN is reported:
[ WARN] [1667526567.784699137, 37.720000000]: PositionTargetGlobal failed because no origin
[ WARN] [1667526567.884896969, 37.820000000]: PositionTargetGlobal failed because no origin
[ WARN] [1667526567.986382705, 37.920000000]: PositionTargetGlobal failed because no origin
[ WARN] [1667526568.085725849, 38.020000000]: PositionTargetGlobal failed because no origin
[ WARN] [1667526568.187087564, 38.120000000]: PositionTargetGlobal failed because no origin
[ WARN] [1667526568.287900686, 38.220000000]: PositionTargetGlobal failed because no origin
[ WARN] [1667526568.387957046, 38.320000000]: PositionTargetGlobal failed because no origin
[ WARN] [1667526568.489057774, 38.420000000]: PositionTargetGlobal failed because no origin
When I try “commander takeoff” instruction, this WARN reported too.
I have tried many aircrafts , this problem always exist.
I should mention that everything is ok before today.
Is anyone else having the same problem as me?
THANKS.
I have too,but it seems ok to run,i guess it is because we are using the local position target but not global
Same issue here, using SITL simulation with gazebo and fixed-wing plane. Would appreciate any help to solve this issue.
Thanks in advance!
In order to get rid of PositionTargetGlobal failed because no origin message:
This message comes from guided_target plugin (guided_target: accept position-target-global-int messages by snktshrma · Pull Request #1780 · mavlink/mavros · GitHub), which as far as I understood is used for getting global position messages in scaled int from GCS.
We can do one of the two approaches:
  • don’t load this plugin by editing the file /opt/ros/humble/share/mavros/launch/px4_pluginlists.yaml and adding the guided_target plugin to the list of plugin_denylist. I tried this and it does not seem to have major side effect. This method is good for when we have installed mavros binary packages using apt.
  • build mavros from latest code. There the problem is fixed I think: SensorQoS necessary for gp_origin? · Issue #1911 · mavlink/mavros · GitHub (not sure of course)
Version of the file, whithout a fix, which I think is used in the binary package: mavros/mavros_extras/src/plugins/guided_target.cpp at 65ad32e7329ac9a54a1afa8691a89e2fc611ad30 · mavlink/mavros · GitHub
Version of the file with the fix in latest code: mavros/mavros_extras/src/plugins/guided_target.cpp at 227bb05c34a75188f1d6fccff6f767d0cc9129b0 · mavlink/mavros · GitHub
Probably related error message in Mavros output:
[mavros_node-1] [INFO] [1707929198.436637057] [mavros.mavros]: Plugin guided_target initialized
[mavros_node-1] [WARN] [1707929198.436743442] [mavros.global_position]: New subscription discovered on topic '/mavros/global_position/gp_origin', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
[mavros_node-1] [WARN] [1707929198.437238814] [mavros.guided_target]: New publisher discovered on topic '/mavros/global_position/gp_origin', offering incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
[mavros_node-1] [INFO] [1707929198.446975237] [mavros.mavros]: Plugin hil created
