Reading UART from other sensors
I am attempting to integrate some other sensors to use in conjunction with the PX4 system. I have the dev environment setup and have built various modules which run from the shell. These sensors are UART based, and I am having trouble finding information on the forums and docs as to the proper techniques to acquire UART data.
So far I am able to initialize a UART port, set the baud rate and settings, and even send characters over the UART to a terminal. I was wondering what the best way to capture UART data is. I have found ::read(…) function to acquire single bytes from the buffer. Is there a mechanism built in to automatically execute callbacks when data is received/ buffer is full? How can I query the buffer size for a UART?
For example, I have a sensor which sends out 32 bytes with a terminating character ten times a second. Do I have to manually read the buffer byte by byte and compile the UART string based on finding the termination characters? Or are there functions within PX4 which I can assign callbacks from? Depending on the OS I assume that I may not be able to read the buffer byte by byte in real time when operating as a deamon task. Do I just incrementally read the buffer byte by byte every time my function executes?
Thanks in advance!
Are you able to figure it out? Please help me in this regard.
Were you able to figure it out?
