Qt creqtor error
I encountered an error while running the QGC code. This is my first experience with QT Android development applications.
02:17:07: Exécution des étapes pour le projet qgroundcontrol…
02:17:07: Débute : “C:\Qt\5.15.2\android\bin\qmake.exe” C:\Users\elied\Bureau\qgc\qgroundcontrol\qgroundcontrol.pro -spec android-clang “CONFIG+=debug” “CONFIG+=qml_debug” ANDROID_ABIS=“armeabi-v7a arm64-v8a”
Project MESSAGE: Qt version 5.15.2
Project MESSAGE: Android Arm 64 bit build
Project MESSAGE: Daily Build
Project MESSAGE: GIT_DESCRIBE
Project MESSAGE: QGroundControl APP_VERSION_STR VERSION vUnknown 0.0.0
Project MESSAGE: VERSION 0.0.0
Project MESSAGE: Android version info: 660000000 bitness:66 major:0 minor:0 patch:00 dev:000
Project MESSAGE: Debug flavor
Project MESSAGE: Skipping support for Pairing
Project MESSAGE: Using MAVLink dialect ‘ardupilotmega’.
Project MESSAGE: ANDROID_EXTRA_LIBS
Project MESSAGE: arm64-v8a
Project MESSAGE: C:/Users/elied/Bureau/qgc/qgroundcontrol/libs/OpenSSL/android_openssl/no-asm/latest/arm/libcrypto_1_1.so C:/Users/elied/Bureau/qgc/qgroundcontrol/libs/OpenSSL/android_openssl/no-asm/latest/arm/libssl_1_1.so C:/Users/elied/Bureau/qgc/qgroundcontrol/libs/OpenSSL/android_openssl/no-asm/latest/arm64/libcrypto_1_1.so C:/Users/elied/Bureau/qgc/qgroundcontrol/libs/OpenSSL/android_openssl/no-asm/latest/arm64/libssl_1_1.so C:/Users/elied/Bureau/qgc/qgroundcontrol/libs/OpenSSL/android_openssl/no-asm/latest/x86/libcrypto_1_1.so C:/Users/elied/Bureau/qgc/qgroundcontrol/libs/OpenSSL/android_openssl/no-asm/latest/x86/libssl_1_1.so C:/Users/elied/Bureau/qgc/qgroundcontrol/libs/OpenSSL/android_openssl/no-asm/latest/x86_64/libcrypto_1_1.so C:/Users/elied/Bureau/qgc/qgroundcontrol/libs/OpenSSL/android_openssl/no-asm/latest/x86_64/libssl_1_1.so
Project MESSAGE: Skipping support for Zeroconf (unsupported platform)
Project MESSAGE: Including support for AirMap
Project MESSAGE: Taisync disabled
Project MESSAGE: Microhard disabled
Project MESSAGE: Skipping support for video streaming (GStreamer libraries not installed)
Project MESSAGE: Installation instructions here: qgroundcontrol/src/VideoReceiver/README.md at aa0f2c61b2c0dbf1913f1f8186312811ca7dbdeb · mavlink/qgroundcontrol · GitHub
Project MESSAGE: Adding Serial Java Classes
Project MESSAGE: This project is using private headers and will therefore be tied to this specific Qt module build version.
Project MESSAGE: Running this project against other versions of the Qt modules may crash at any arbitrary point.
Project MESSAGE: This is not a bug, but a result of using Qt internals. You have been warned!
Project MESSAGE: Android Arm 32 bit build
Project MESSAGE: Android version info: 340000000 bitness:34 major:0 minor:0 patch:00 dev:000
Project MESSAGE: armeabi-v7a
02:17:23: The process “C:\Qt\5.15.2\android\bin\qmake.exe” exited normally.
02:17:23: Débute : “C:\Users\elied\AppData\Local\Android\Sdk\ndk\19_2_5345600\prebuilt\windows-x86_64\bin\make.exe” -f C:/Users/elied/Bureau/qgc/build-qgroundcontrol-Android_Qt_5_15_2_Clang_Multi_Abi-Debug/Makefile qmake_all
make: Nothing to be done for qmake_all'. 02:17:23: The process "C:\Users\elied\AppData\Local\Android\Sdk\ndk\19_2_5345600\prebuilt\windows-x86_64\bin\make.exe" exited normally. 02:17:23: Débute : "C:\Users\elied\AppData\Local\Android\Sdk\ndk\19_2_5345600\prebuilt\windows-x86_64\bin\make.exe" -j4 C:/Users/elied/AppData/Local/Android/Sdk/ndk/19_2_5345600/prebuilt/windows-x86_64/bin/make -f Makefile.Armeabi-v7a all C:/Users/elied/AppData/Local/Android/Sdk/ndk/19_2_5345600/prebuilt/windows-x86_64/bin/make -f Makefile.Arm64-v8a all make[1]: Entering directory C:/Users/elied/Bureau/qgc/build-qgroundcontrol-Android_Qt_5_15_2_Clang_Multi_Abi-Debug’
make[1]: Entering directory C:/Users/elied/Bureau/qgc/build-qgroundcontrol-Android_Qt_5_15_2_Clang_Multi_Abi-Debug' rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\qgroundcontrol.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\qgroundcontrol.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\qgcresources.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\qgcresources.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\qgcimages.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\qgcimages.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\resources\InstrumentValueIcons\InstrumentValueIcons.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\resources\InstrumentValueIcons\InstrumentValueIcons.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\UnitTest.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\UnitTest.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\src\FirmwarePlugin\APM\APMResources.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\src\FirmwarePlugin\APM\APMResources.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\src\FirmwarePlugin\PX4\PX4Resources.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\src\FirmwarePlugin\PX4\PX4Resources.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\src\Airmap\dummy\airmap_dummy.qrc rcc C:\Users\elied\Bureau\qgc\qgroundcontrol\src\Airmap\dummy\airmap_dummy.qrc rcc armeabi-v7a\qmake_qmake_qm_files.qrc rcc arm64-v8a\qmake_qmake_qm_files.qrc RCC: Error in 'armeabi-v7a\qmake_qmake_qm_files.qrc': Cannot find file 'C:/Users/elied/Bureau/qgc/build-qgroundcontrol-Android_Qt_5_15_2_Clang_Multi_Abi-Debug/armeabi-v7a/qgc_az_AZ.qm' make[1]: *** [armeabi-v7a\qrc_qmake_qmake_qm_files.obj] Error 1 make[1]: Leaving directory C:/Users/elied/Bureau/qgc/build-qgroundcontrol-Android_Qt_5_15_2_Clang_Multi_Abi-Debug’
make: *** [armeabi-v7a-all] Error 2
make: *** Waiting for unfinished jobs…
RCC: Error in ‘arm64-v8a\qmake_qmake_qm_files.qrc’: Cannot find file ‘C:/Users/elied/Bureau/qgc/build-qgroundcontrol-Android_Qt_5_15_2_Clang_Multi_Abi-Debug/arm64-v8a/qgc_az_AZ.qm’
make[1]: *** [arm64-v8a\qrc_qmake_qmake_qm_files.obj] Error 1
make[1]: Leaving directory `C:/Users/elied/Bureau/qgc/build-qgroundcontrol-Android_Qt_5_15_2_Clang_Multi_Abi-Debug’
make: *** [arm64-v8a-all] Error 2
02:17:28: Le processus “C:\Users\elied\AppData\Local\Android\Sdk\ndk\19_2_5345600\prebuilt\windows-x86_64\bin\make.exe” s’est terminé avec le code 2.
Erreur lors de la compilation/déploiement du projet qgroundcontrol (kit : Android Qt 5.15.2 Clang Multi-Abi)
When executing step “Make”
02:17:28: Elapsed time: 00:21.
Any help pleqse?
Did you follow the android setup for qgc from this manual
https://doc.qt.io/qt-5/android-getting-started.html#android-sdk
