Pymavlink is not working proporly in SITL
hello, i am trying to use PX4 with pymavlink but no matter how hard i tried , the drone is not working accprding to mav messages. I have tried to control the drone using qground control and it works properly with qgroundcontrol. But using pymavlink seems to be the issue. can anybody help me??
i have checked and PX4 works well with mavsdk, but not with pymavlink!!
here is the code that usese pymavlink
import time
from pymavlink import mavutil
master = mavutil.mavlink_connection("udp:127.0.0.1:14550")
master.wait_heartbeat()
print("Heartbeat from system (system %u component %u)" % (master.target_system, master.target_component))
master.mav.request_data_stream_send(master.target_system, master.target_component, mavutil.mavlink.MAV_DATA_STREAM_ALL, 1, 1)
# Wait for and print the altitude from GLOBAL_POSITION_INT messages
while True:
    msg = master.recv_match(type='GLOBAL_POSITION_INT', blocking=True)
    print(msg)
    if msg:
        altitude = msg.relative_alt / 1000.0
        print("Altitude: %.2f meters" % altitude)
        break
master.mav.command_long_send(
    master.target_system,  # target system
    master.target_component,  # target component
    mavutil.mavlink.MAV_CMD_COMPONENT_ARM_DISARM,  # command
    1,  # confirmation
    1,  # param1 (1 to indicate arm)
    0,  # param2 (unused)
    0,  # param3 (unused)
    0,  # param4 (unused)
    0,  # param5 (latitude, unused)
    0,  # param6 (longitude, unused)
    0  # param7 (altitude, unused)
print("Arm command sent!")
# Wait for a COMMAND_ACK message
while True:
    msg = master.recv_match(type='COMMAND_ACK', blocking=True)
    if msg:
        print(msg)
        break
# master.mav.set_mode(4)
time.sleep(5)
    mavutil.mavlink.MAV_CMD_NAV_TAKEOFF,  # command
    1,  # confirmation
    0,  # param1 (unused)
    700  # param7 (altitude)
while True:
    if msg:
        print(msg)
        break
while True:
    if msg:
1, # confirmation
float(“NAN”), # param5 (latitude, unused)
float(“NAN”), # param6 (longitude, unused)
1200 # param7 (altitude)
I tested it on my computer and it worked normally.
what simulator you are using? i have noticed that the autopilot works differently simulator to simulator.
jamvism gazebo(new) all can
