Windows 10 toolchain.
SITL with jMAVSim (headless)
BUILD SUCCESSFUL
Total time: 0 seconds
Options parsed, starting Sim.
GUI not enabled
INFO [simulator] Simulator connected on TCP port 4560.
Init MAVLink
INFO [commander] LED: open /dev/led0 failed (22)
INFO [init] Mixer: etc/mixers/quad_w.main.mix on /dev/pwm_output0
INFO [mavlink] mode: Normal, data rate: 4000000 B/s on udp port 18570 remote port 14550
INFO [ecl/EKF] 912000: EKF aligned, (baro height, IMU buf: 22, OBS buf: 14)
INFO [ecl/EKF] 912000: reset position to last known position
INFO [ecl/EKF] 912000: reset velocity to zero
INFO [logger] Opened full log file: ./log/2020-03-19/15_59_09.ulg
INFO [mavlink] MAVLink only on localhost (set param MAV_BROADCAST = 1 to enable network)
pxh> INFO [ecl/EKF] 9888000: GPS checks passed (WGS-84 origin set)
INFO [ecl/EKF] 14416000: reset position to GPS
INFO [ecl/EKF] 14416000: reset velocity to GPS
INFO [ecl/EKF] 14416000: commencing GPS fusion
INFO [mavlink] partner IP: 127.0.0.1
INFO [commander] Takeoff detected
INFO [commander] Landing at current position
INFO [commander] Landing detected
INFO [logger] closed logfile, bytes written: 1596341
WARN [commander] Data link lost
INFO [logger] Opened full log file: ./log/2020-03-19/15_59_53.ulg
INFO [logger] closed logfile, bytes written: 697565
I can run at most a few tests (running python scripts using MAVSDK) but then the drone becomes unresponsive. I can only shut down and restart.
If I check mavlink status:
pxh> mavlink status
instance #0:
mavlink chan: #0
type: GENERIC LINK OR RADIO
flow control: OFF
rates:
tx: 13.614 kB/s
txerr: 0.000 kB/s
tx rate mult: 1.000
tx rate max: 4000000 B/s
rx: 0.000 kB/s
FTP enabled: YES, TX enabled: YES
mode: Normal
MAVLink version: 1
transport protocol: UDP (18570, remote port: 14550)
instance #1:
GCS heartbeat: 17612000 us ago
mavlink chan: #1
flow control: OFF
rates:
tx: 24.761 kB/s
txerr: 0.000 kB/s
tx rate mult: 1.000
rx: 0.000 kB/s
mode: Onboard
MAVLink version: 2
transport protocol: UDP (14580, remote port: 14540)
I don’t understand, but it seems to me that PX4 and jMAVSim no longer communicate, but I can’t understand why and where this happens.
Please help.
