PX4 Sync / Q&A: Feb 19, 2025
Dronecode Calendar
Agenda
  • Announcements
  • Future Events
  • Flight Testing Update
  • Release Discussion
  • Bug Report / Q&A
Announcements
Future Events
We are running a beta program with Ascend Engineering (Chicago). They will be running flight testing for the community as part of an arrangement with Dronecode
How to reach out to the team
  • GitHub: Tag user @PX4/testflights
  • Discord: #flight-testing
  • Weekly on the PX4 Dev Call
How to Request Testing (GitHub)
  • Write down the steps to test your issue/pull request
    • Make sure to note the risk involved in flying
    • Write down things to look out for / anticipate - eg: “we are looking for no yaw jumps”
  • Add issue/pull request to the Flight Testing project board
  • Make sure to specify any hardware/software requirements as much as possible
Flight Testing board:
:point_down: :point_down: :point_down:
GitHub
Flight Testing :airplane: • PX4
Discussion
Comments:
  • Broader range of boards to be tested
  • More specific features
Release Discussion
Project Board
For release coordination, we will be using the project board.
:point_down:
Project Board Link
v1.16 Release
Discussion
Bug report / Q&A
1- CI testing PX4 Internal and External (ROS2) code · Issue #24363 · PX4/PX4-Autopilot · GitHub
A CI is needed, @farhang @rroche will work on that.
2- @stevejohn163 I’m trying to initiate a takeoff using the MAV_CMD_NAV_TAKEOFF command via COMMAND_INT. The problem is that when I set the altitude with different MAV_FRAME values, the takeoff altitude doesn’t change as expected. No matter which MAV_FRAME I use and set the takeoff altitude to 2.5m, it always tries to take off to 2.5m. However, since I’m already at an altitude of 200m above mean sea level, it throws the error: “Already higher than takeoff altitude.”
Currently, I have to manually retrieve the MSL (mean sea level) altitude, add 2.5m to it, and send that value via COMMAND_INT for it to work properly.
3- PX4 autopilot ROS2 user guide problem
Maybe we can make targets more specific?
PRs needing review
  • CMake needs to be fixed first to have it tested. (preferrably Nuttx and PX4 build separated to avoid build errors)
  • Eigen is not used on PX4 side much (has a similar lib however) so maybe using Eigen is not going to be an idea.
Hi, I’m trying to add neural network support for px4 to lower the barrier for using RL on UAVs in research. I have some make problems, and was wondering if someone could help me. I will be attending the sync call.
Need a second look on this PR: Faster than Real -Time support in GZ by dirksavage88 · Pull Request #23783 · PX4/PX4-Autopilot · GitHub
https://github.com/PX4/PX4-Autopilot/blob/04a3c4af20df9e851e281776bfa51d02759ddee6/src/modules/navigator/takeoff.cpp#L117
