I am trying to get the RTPS bridge working: ROS 2 User Guide (PX4-ROS 2 Bridge) | PX4 User Guide and have run into 2 situations:
1: On a Jetson Nano running Ubuntu 20.04, I can follow the sanity check until the fourth step, which runs but doesn’t print the sensor data:
jetson@nano:~$: source ~/px4_ros_com_ros2/install/setup.bash
jetson@nano:~$: ros3 launch px4_ros_com sensor_combined_listener.launch.py
[INFO] [launch]: All log files can be found below /home/jetson/.ros/log/2022-
07-11-09-27-40-509653-nano-16128
[INFO] [launch]: Default logging verbosity is set to INFO
/home/jetson/px4_ros_com_ros2/install/px4_ros_com/share/px4_ros_com/launch/se
nsor_combined_listener.launch.py:50: UserWarning: The parameter 'node_executable'
is deprecated, use 'executable' instead
launch_ros.actions.Node(
[INFO] [sensor_combined_listener-1]: process started with pid [16146]
[sensosr_combined_listener-1] Starting sensor_combined listener node...
However if I run
ros2 topic list
I can see the /fmu/sensor_combined/out topic
But running
ros2 topic echo /fmu/sensor_combined/out
or
ros2 topic hz /fmu/sensor_combined/out
results in
ModuleNotFoundError: No module named 'px4_msgs'
2: On my laptop, also running Ubuntu 20.04, the python script
ros2 launch px4_ros_com sensor_combined_listener.launch.py
is able to show the sensor data, but if I try to echo or see the refresh rate of the topic, I also get a ModuleNotFoundError: No module named ‘px4_msgs’
In my px4_ros_com_ros2 directory on both the Jetson and laptop, I have cloned px4_ros_com and px4_msgs
Thanks for your help!
