PX4 Dev Call: June 03, 2020
June 03, 2020
Agenda
  • Status update by component/project
  • Roadmap, and Release discussion
  • Community Q&A
  • In-Depth discussions
Join Meeting
Meeting ID: 946 175 205
Call in using your phone, find your local number: https://zoom.us/u/aetSYKbiMF
Component update
System Architecture
No updates
OS / NuttX
Issue fixed in NuttX upstream related to DMA, it was the root cause for the durandal not working. There’s chatter about a new version 2 months out from NuttX master.
FMU v6x bring up changes are work in progress and should get merged soon. Probably next week.
Driver
@bkueng found an issue with the changed gyroscope filtering. @dagar mentioned the different order was under discussion with @jkflying.
Invensense fixes:
New drivers for BMI88 BMI55:
The new drivers should move into the manufacturer folder and at some point when they’re well tested we can remove the old ones.
Commander
No updates.
Estimation
Issue fixed with the yaw estimator when the unobservable gyro bias gets too high on the ground which results in spinning heading and no convergence:
Solution for the reported altitude problems with 1.11
VTOL
No updates.
Fixed Wing
No updates.
Multicopter
Proposal to remove an unexpected feature. Follow up needs to be to remove maximum altitude from the land detector message.
MAVSDK
New releases with bugfixes/small improvements:
Python reference docs: http://mavsdk-python-docs.s3-website.eu-central-1.amazonaws.com/
Documentation
GitHub pages migration of all the docs. MAVLink DNS works fine now. QGC still has a HTTPS certificate issue @LorenzMeier is looking into it.
Question about styles between the docs. @LorenzMeier is asking if it makes sense to distinguish dev guide and user guide. There are multiple people in the call agreeing that it is quite confusing to have content distributed over both. We have to talk to @hamishwillee but the consensus is that merging the two guides could avoid a lot of confusion. It would probably be structured to start out with usage and configuration instructions and go more in depth after that is covered. E.g. high level first install QGC and fly and then install toolchain.
MAVROS / RTPS / ROS2
No updates.
There seem to be issues with certain CI tests catkin, offboard attitude. @dagar proposes to comment not passing tests out and assigning issues to the right people to fix them since we cannot start dragging prs out because of the repeatedly failing tests. He’ll do that after the call.
Avoidance
No updates.
Simulation
MacOS toolchain was broken and now it’s fixed. Homebrew simulation package maintained by osrf was broken for some weeks and was fixed.
UAVCAN
For UAVCAN v1 we get close to something mergeable that we can start using.
NXP successfully tested UAVCAN v1 implementation with their BMS and RDDrone S32k board.
There’s various reviews and tests going on for the message definitions. The idea is to have them in the dronecode organization and use them in PX4.
Summary blocking for v1 public beta:
  • Define repository
  • Define message namespace
  • Pick message IDs
There’s a dedicate call on that every Tuesday. Join next week if you’re interested.
See Dronecode calendar: https://www.dronecode.org/calendar/
Blocking altitude issues were solved, see Estimation. @dagar solved a lot of small blocking issues. The release candidate is around the corner ICM issue, ESC calibration are the only possible remaining blockers he can think of at the moment. We’ll check those and
Community Q&A
brianphilips: Suggestion to simplify the adoption of MAVSDK by providing issue templates for feature request and bug reports like on PX4. This is a great idea and it’s highly appreciated if there was a pull request for templates.
Errata and Feedback
I will be joining this call. I would like to briefly talk about the following topics if possible, or schedule a time to speak with the lead devs.
  • Creating template for issues and PRs like with PX4 but in MAVSDK
Great, I’ll add you to the agenda under Community Q&A. Thanks @unipheas
ThoneFlow Optical flow module driver is almost ready to merge
Attendees:
@dagar
@unipheas
@jkflying
@TThing
@david_s5
@JulianOes
@bys_1123
@feemi
@bresch
@MaEtUgR
@LorenzMeier
@TSC21
@Jaeyoung-Lim
@sfuhrer
DRF
Howard G.
Chen Qirong
Mical
