PX4 Build Error: CMake Error at cmake/px4_add_module.cmake:236 (get_target_property): get_target_property() called with non-existent target "drivers__uavcan"
I want to add a radar distance sensor based on CAN communication. I want to use the driver provided by the src/drivers/uavcan library as the underlying communication driver of CAN. This error message appears when making dependencies. Does anyone know how to solve this error?
src/distance_sensor/radar_can/CMakeLists.txt:
px4_add_module(
	MODULE drivers__distance_sensor__radar_can
	MAIN radar_can
	COMPILE_FLAGS
		-Wno-cast-align # TODO: fix and enable
	INCLUDES
		${PX4_SOURCE_DIR}/src/drivers/uavcan
	SRCS
		radar_can.cpp
		radar_can_main.cpp
	DEPENDS
		px4_work_queue
		drivers_rangefinder
		drivers__uavcan
could it simply be the double underscore?
try: drivers_uavcan
instead of drivers__uavcan
I tried it, still the same error!Because there is a related definition in the uavcan driver:
px4_add_module(
	MODULE drivers__uavcan
	MAIN uavcan
	STACK_MAIN 4096
	COMPILE_FLAGS
		-Wno-format-security # logmessage.hpp
		#-O0
		#-DDEBUG_BUILD
	INCLUDES
		${DSDLC_OUTPUT}
		${LIBUAVCAN_DIR}/libuavcan/include
		${LIBUAVCAN_DIR}/libuavcan/include/dsdlc_generated
		${LIBUAVCAN_DIR}/libuavcan_drivers/posix/include
		${LIBUAVCAN_DIR_DRIVERS}/${UAVCAN_DRIVER}/driver/include
	SRCS
		arming_status.cpp
		arming_status.hpp
		beep.cpp
		beep.hpp
		rgbled.cpp
		rgbled.hpp
		safety_state.cpp
		safety_state.hpp
		# Main
		uavcan_main.cpp
		uavcan_servers.cpp
		# Actuators
		actuators/esc.cpp
		actuators/hardpoint.cpp
		actuators/servo.cpp
		# Sensors
		sensors/sensor_bridge.cpp
		sensors/differential_pressure.cpp
		sensors/baro.cpp
		sensors/battery.cpp
		sensors/airspeed.cpp
		sensors/flow.cpp
		sensors/gnss_relative.cpp
		sensors/gnss.cpp
		sensors/mag.cpp
		sensors/rangefinder.cpp
		sensors/accel.cpp
		sensors/gyro.cpp
		sensors/ice_status.cpp
		sensors/hygrometer.cpp
		sensors/safety_button.cpp
	MODULE_CONFIG
		module.yaml
	DEPENDS
		px4_uavcan_dsdlc
		button_publisher
		drivers_rangefinder
		led
		mixer_module
		version
		git_uavcan
		uavcan_${UAVCAN_DRIVER}_driver
		drivers_rangefinder # Fix undefined reference when no distance sensors are selected
		# within libuavcan
		uavcan
