Hi there,
I am trying to change the PWM Min and Max for the AUX 5 of Pixhawk 2. I am using PX$ Autopilot Version 1.8.0.
I tried changing the PWM_MIN and PWM_MAX from parameter section but the Aux Pin PWM did not reflect the changes.
I also tried changing the PWM_AUX_MIN and MAX from the mavlink console using the param set command, but that also did not work.
Is there any other way to change the PWM min and max value of an AUX pin?
@DevTeam You help is highly appreciated.
