Publish position setpoints in Body coordinate frame using Mavros
Hello, I hope I am posting in the right section.
I am a relatively new user of mavros and px4, and I am trying to publish positions setpoints by publishing into the setpoint_position/local topic. I got started using the optical flow iris gazebo model and the Python Offboard examples on dev.px4.io (using a slightly modified version of mavros_test_common to disable the GPS and home position checks).
I am trying to send setpoints relative to the current position of the drone. I thought of using subscribers to read the current local pose and publishing the setpoints relative to those but it seems very convoluted. I suspect changing the frame of reference to be body fixed should be simpler.
I am quite confused about the current coordinate frames used to publish the setpoints. At the moment positive x seems to correspond to North, positive y to West and positive z to Up, which does not correspond to any coordinate frames I ve encountered. In the example, the frame_id parameter is set to “base_footprint”, but I have tested with any other string and it yields the same results.
What process should I follow to change the frame of reference to body fixed? Is there any example python code available that I can follow?
Maybe using setpoint_raw messages would work better, but I did not find a resource listing the bitmasks that should be used.
Thanks for your help.
The coordination is on the pixhawk PCB, it has its own coordination system. I’am also learning how to set point.
