Pixhawk4 buzzer flows mV not 5V
I am trying to use a separate RTK GPS rather than the GPS provided by Pixhawk4.
Pixhawk4 uses the drone’s buzzer and switch for the GPS terminal. I connected the GPS pins, the switch pin, and the buzzer pin as shown in the figure below, and the GPS was connected well.
But the buzzer and switch don’t work. The pinout of Pixhawk4 says 5V flows to the + pin of the buzzer, but it was confirmed that 0.1~0.2V was flowing when actually measured.
I was expecting 5V to flow just by connecting it, but I’m disappointed it doesn’t. Why doesn’t 5V flow? What additional work do I need to do?
Hi, faced the same problem recently. I put a non-standard GPS plugged in and my speaker was quiet. I checked all the outputs and noticed an error in the circuit in the user manual. I have solved the given problem. Any passive buzzer with a resistance of about 16 ohms is required. We connect it between the 9 outputs (buzzer -) and the + 5V positive output and everything works.
