Recently I had a vital drone crash equipped with Pixhawk Cube Orange. The issue is I am unable to power only peripherals/components using power module from power1 port but able to power it through USB.How can I check what has gone wrong.
I got the same issue, after a crash, I’ll try to power up using usb pins
What peripherals are you using? Some peripherals draw too much current, so they will cause the vehicle to “brown out” if they momentarily draw too much current.
Sounds like you damaged something. Flying powered by USB is not recommended.
