Hi Julian, thanks for this! Here are the things required to reproduce:
Holybro Pixhawk 6C with the following versions:
The firmware version can also be v1.13.0, v1.13.1, or v1.13.2 - Any of the following WiFi modules: ESP-WROOM-32 (the version I bought was this), WeMos D1 Mini Pro ESP8266 (the version I bought was this), or NodeMCU ESP8266-v3 (the version I bought was this)
- ESP8266 was flashed with firmware V1.2.2, connected to TELEM1, ser1 baud rate set to
921600. All the default firmware settings were used, but I changed the mode to station mode and connected it to my own router. - ESP32 was flashed with DroneBridge v1.0 (DroneBridgeESP32_v1_1.zip), connected to TELEM1, ser1 baud rate set to
115200. All the default firmware settings were used.
- The wiring from TELEM1 to the WiFi module was like this:
- ESP8266
- ESP32
- ESP8266
Please let me know if any further information is required on your end. Thanks again!
