Pixhawk 4 and PM07 soldering and wiring
How can I should use pixhawk4 with PM07 power module ?
It’s the first time I’m using this power module with here4 GPS module and c13 skydroid camera and raspberry Pi and it’s a quadcopter.
Hi there!
You can directly connect the PWR1 or PWR2 ports of the PM07 to the POWER1 of the Pixhawk4.
And what about the other connections in Pm07
Can you explain in a bit more detail what you are trying to do?
  • Connect a standard GPS?
  • Connect a Camera
  • Connect a Raspberry Pi as companion computer?
  • Connect the motors to the ESC?
  • Something else?
All of these …
I’m using pixhawk 4,skydroid c13,skydroid G12 and here 4 GPS
I urge you to look at resources that are already out there. This is pretty standard stuff that can easily be found with a simple google search.
If you get stuck, you can ask me again, but I need a bit more specific problem, to help you effectively.
Start with the GPS, as this should be the easiest.
Flight test was successful with everything including camera feed ,gps etc but the real question is whether to integrate CC or not to calculate target lat lon?
As I’ve studied MP itself has some scripts that can be used for providing custom commands to PIXHAWK or PX4!?
Congratulations on the flight test.
Unfortunately, I cannot follow the rest, but I assume its about a different topic. If so, please use another thread.
