Hi, I am trying to individually check all the motors to our drone. We are using a pixhawk autopilot Pro and using QGround Control v3.3.2 When using the PWM test commands, only channel 1 is responding. At first, I thought it was a hardware problem so I plugged each rotor into channel 1 and they all responded, so I know its a software problem. Does anyone have any idea what could be causing this or any solutions to this problem? Thank You, anything will be helpful
Related topics
| Topic | Replies | Views | Activity | |
Motor only working when channel assigned to function "Motor 3" in QGroundControl
1 | 12 | February 18, 2026 | |
| Benchtop Test of Motors with QGC - Motors run individually but not all at the same time | 1 | 265 | November 22, 2021 | |
| Problem with channel 2 on PWM | 1 | 333 | August 25, 2023 | |
| Pixhawk 4 FMU PWM OUT Channel Malfunction, PX4 VERSION 1.8.2 STANDARD AIRPLANE | 1 | 2978 | July 29, 2019 | |
Motors suddenly not responding
1 | 1229 | January 22, 2018 |
