Hello!
I want use offboar mode but when I want turn on offboard mode in QGC I get messange: “main state transition denied”?
How can I turn on offboard mode?
Thanks!!
Hello!
Thanks!!
Offboard mode is pretty dangerous. Before turning on the offboard mode, I think you should read the documentation thoroughly. I suppose you have to send offboard setpoints within the first 0.5 seconds of switching to offboard mode, which is overcome by sending a few setpoints right before switching to offboard mode. You can see the code here
https://dev.px4.io/en/ros/mavros_offboard.html
Hello! Thanks for answering @deksprime .
How can I send the offboard setpoint within the range of 0.5?
You can use ROS, specifically MAVROS to interface with PX4, using a companion computer. As I have mentioned in my previous comment, it is all written in this mavros_offboard example.
Ok, I will try to run the example/. Thanks!!
I’ll tell you later if the offboard mode run @deksprime
