I am interfacing X-Plane with PX4 SITL using MAVLink and running into persistent issues with HIL_SENSOR messages. Even though my messages seem correctly formed and are sent with appropriate timing, I am receiving a recurring error: ERROR [simulator_mavlink] Number of simulated accelerometer out of range. Max: 3.
I am attempting to send simulated sensor data from X-Plane to PX4 SITL, with specific focus on HIL_SENSOR messages. I have ensured that the connection is well-established and that messages are appropriately timed and structured. Despite these precautions, the aforementioned error keeps appearing, indicating a potential misinterpretation of the messages by PX4.
Code Snippets:
Here are relevant portions of my code where I structure and dispatch the HIL_SENSOR messages:
void MAVLinkManager::sendHILSensor() {
if (!ConnectionManager::isConnected()) return;
mavlink_message_t msg;
mavlink_hil_sensor_t hil_sensor;
hil_sensor.time_usec = static_cast<uint64_t>(DataRefManager::getFloat("sim/time/total_flight_time_sec") * 1e6);
hil_sensor.xacc = DataRefManager::getFloat("sim/flightmodel/forces/g_axil") * DataRefManager::g_earth;
hil_sensor.yacc = DataRefManager::getFloat("sim/flightmodel/forces/g_side") * DataRefManager::g_earth;
hil_sensor.zacc = DataRefManager::getFloat("sim/flightmodel/forces/g_nrml") * DataRefManager::g_earth;
hil_sensor.xgyro = DataRefManager::getFloat("sim/flightmodel/position/Prad");
hil_sensor.ygyro = DataRefManager::getFloat("sim/flightmodel/position/Qrad");
hil_sensor.zgyro = DataRefManager::getFloat("sim/flightmodel/position/Rrad");
hil_sensor.abs_pressure = DataRefManager::getFloat("sim/weather/barometer_current_inhg") * 33.8639;
hil_sensor.pressure_alt = DataRefManager::getDouble("sim/flightmodel2/position/pressure_altitude") * 0.3048;
// Find suitable datarefs or provide default values
hil_sensor.diff_pressure = 0;
hil_sensor.xmag = 0;
hil_sensor.ymag = 0;
hil_sensor.zmag = 0;
hil_sensor.temperature = DataRefManager::getFloat("sim/cockpit2/temperature/outside_air_temp_degc");
// Now set the bits for the fields you are updating.
// Refer to the provided enum values for the fields_updated flags.
//https://mavlink.io/en/messages/common.html#HIL_SENSOR_UPDATED_FLAGS
uint32_t fields_updated = 0; // Start with a bitmask of all zeros
fields_updated |= (1 << 0); // HIL_SENSOR_UPDATED_XACC, the bit shift corresponds to setting the 0th bit to 1
fields_updated |= (1 << 1); // HIL_SENSOR_UPDATED_YACC, the bit shift corresponds to setting the 1st bit to 1
fields_updated |= (1 << 2); // HIL_SENSOR_UPDATED_ZACC, the bit shift corresponds to setting the 2nd bit to 1
fields_updated |= (1 << 3); // HIL_SENSOR_UPDATED_XGYRO, the bit shift corresponds to setting the 3rd bit to 1
fields_updated |= (1 << 4); // HIL_SENSOR_UPDATED_YGYRO, the bit shift corresponds to setting the 4th bit to 1
fields_updated |= (1 << 5); // HIL_SENSOR_UPDATED_ZGYRO, the bit shift corresponds to setting the 5th bit to 1
fields_updated |= (1 << 9); // HIL_SENSOR_UPDATED_ABS_PRESSURE, the bit shift corresponds to setting the 9th bit to 1
fields_updated |= (1 << 11); // HIL_SENSOR_UPDATED_PRESSURE_ALT, the bit shift corresponds to setting the 11th bit to 1
fields_updated |= (1 << 12); // HIL_SENSOR_UPDATED_TEMPERATURE, the bit shift corresponds to setting the 12th bit to 1
hil_sensor.fields_updated = fields_updated;
// Finally, assign the bitmask to the hil_sensor message object
mavlink_msg_hil_sensor_encode(1, 1, &msg, &hil_sensor);
uint8_t buffer[MAVLINK_MAX_PACKET_LEN];
int len = mavlink_msg_to_send_buffer(buffer, &msg);
ConnectionManager::sendData(buffer, len);
void ConnectionManager::sendData(const uint8_t* buffer, int len) {
if (!connected) return;
int totalBytesSent = 0;
while (totalBytesSent < len) {
int bytesSent = send(newsockfd, reinterpret_cast<const char*>(buffer) + totalBytesSent, len - totalBytesSent, 0);
if (bytesSent < 0) {
char buf[256];
#if IBM
snprintf(buf, sizeof(buf), "px4xplane: Error sending data: %d\n", WSAGetLastError());
#elif LIN || APL
snprintf(buf, sizeof(buf), "px4xplane: Error sending data: %s\n", strerror(errno));
#endif
XPLMDebugString(buf);
// Optionally, handle error, e.g., clean up and/or reconnect
return;
else if (bytesSent == 0) {
// The peer has closed the connection.
XPLMDebugString("px4xplane: Peer has closed the connection\n");
// Clean up and/or try to reconnect.
return;
totalBytesSent += bytesSent;
And, here is how it’s called in the plugin loop:
float MyFlightLoopCallback(float inElapsedSinceLastCall, float inElapsedTimeSinceLastFlightLoop, int inCounter, void* inRefcon) {
if (!ConnectionManager::isConnected()) return -1.0f;
MAVLinkManager::sendHILSensor();
return -1.0f;
- Could any part of the code be causing PX4 to wrongly perceive the number of accelerometers in the
HIL_SENSORmessage? - Is there any additional information or specific flags in the
fields_updatedbitmask that need to be set or avoided to prevent such discrepancies? - Are there any related known bugs, and if so, are there workarounds or fixes available?
the source code is alsoavaible at
