[NEED HELP] Changing Quadcopter's Motor Rotation Direction Mid-Flight
Hi, I am searching for a way to reverse the rotation of my quadcopter’s motors while in the air. I am planning on using offboard mode to send commands to the drone and I have configured the motors as bidirectional in QGroundControl. My hope is that as soon as the PX4 controller receives a command where it is favorable to reverse the direction of the motors, (in order to create reverse thrust) it will. Will this work? If not, does anyone know of a way?
Any help is appreciated,
Thank you
我觉得这应该可以通过精确控制电机的转速来实现,但是不同的型号电机对应的代码适配应该有问题所以如果获得了相关代码应该要自己微调一下
