Hello guys,
First of all thank you for all the work that you have done. It’s amazing what you archieved.
I am using the QGC to management a home made drone with SiYi communications and 5G.
I was trying to use this two links in the same time, but appear that the QGC can’t select which the one that i pretend to use and what is the primary connection.
Can you help me please?
