Motors not rev up to full even after giving full throttle command
Hello to all respected members. I urgently need some help. Tried chatgpt, googled everything, then I am here asking for help. I am building a custom drone. Flight controller: cube orange+, ESC: Holybro Tekko32 F4 4in1 50A ESC, PX4 version: 1.15.0dev, Motors: 5010, 360kv. My issue is when I raise throttle in my radio the motors spin up at 15-20% suddenly , and stays at same rpm even if I raise the throttle to full**.** Also when I raise throttle in actuators tab in Qgroundcontrol same thing happens. I tried dshot600, pwm esc protocols, moved signal wires of motors to main ports from aux ports, calibrated escs again and again. Selected DSHOT_TEL_CFG = Disable/Enable etc. Checked Output range 1000-2000. But the issue remains the same. Is this could be esc problem or px4 issue?? Any clue would be highly appreciated. Thanks
it must be activating into safety mode…check whether all the safety parameters are checked or else disable safety parameters and try again
But every blocker prior to arm is shown in the message tab in qground control and there are no such messages regarding safety.
