I am working on a new drone project and need to create a mixer with 12 feed through outputs, so I created a vol.main.mix and a vol.aux.mix file with 6 outputs each. I also changed the rcS and interface code to call them up, but doing this I have received some error messages, but not sure why.
[boot] Fault Log is Armed
sercon: Registering CDC/ACM serial driver
sercon: Successfully registered the CDC/ACM serial driver
[i] microSD mounted: /fs/microsd
[hardfault_log] Fault Log is Armed
WARN [param] selected parameter default file /fs/mtd_params
rgbled on I2C bus 2 at 0x55 (bus: 100 KHz, max: 100 KHz)
MS5611_SPI on SPI bus 4 at 2 (20000 KHz)
WARN [ms5611] no device on bus 4
MS5611_SPI on SPI bus 1 at 3 (20000 KHz)
WARN [bst] no devices found
INFO [ver] match: PX4FMU_V2
WARN [hmc5883] no device on bus 1 (type: 2)
WARN [lis3mdl] no device on bus 2
WARN [hmc5883] no device on bus 2 (type: 1)
WARN [mpu6000] no device on bus 5
WARN [mpu9250] no device on bus 4
MPU6000 on SPI bus 1 at 4 (1000 KHz)
WARN [mpu9250] no device on bus 3
L3GD20 on SPI bus 1 at 1 (11000 KHz)
LSM303D on SPI bus 1 at 2 (11000 KHz)
ERROR [meas_airspeed] no MS4525 airspeed sensor connected
ERROR [ets_airspeed] no ETS airspeed sensor connected
INFO [load_mon] stack check enabled
WARN [param] Error: Parameter UAVCAN_ENABLE not found.
INFO [px4io] default PWM output device
INFO [mavlink] mode: Normal, data rate: 1200 B/s on /dev/ttyS1 @ 57600B
INFO [mavlink] mode: OSD, data rate: 1000 B/s on /dev/ttyS2 @ 57600B
px4flow [137:100]
WARN [px4flow] scanning I2C buses for device…
INFO [mavlink] mode: Config, data rate: 800000 B/s on /dev/ttyACM0 @ 57600B
Mixer should exist
INFO [init] Mixer: /etc/mixers/voliro.main.mix on /dev/pwm_output0
ERROR [pwm] PWM_SERVO_SET_SELECT_UPDATE_RATE
Aux Mixer should be loaded here:
INFO [init] Mixer: /etc/mixers/voliro.aux.mix on /dev/pwm_output1
NuttShell (NSH)
nsh> \0x1b[KINFO [lib__ecl] EKF aligned, (pressure height, IMU buf: 21, OBS buf: 16)
WARN [commander] Not ready to fly: Sensors not set up correctly
The error that bugs me the most is the one about the update rate, because I checked and the variable PWM_RATE is 400, but it still gives out this error. A reason for this to happen might be that I commented out the SYS_AUTOSTART feature, because it always set the variables with wrong information.
I also thought about using the IO_pass mixer, since that one is already a passthrough mixer, but I am not sure how to access 12 different outputs. I need 6 outputs for motors and 6 for servos.
I would be happy if anybody might now a elegant why to do this. I think my approach creating all new mixers might be to complicated for the easy mixer I need.
