I’m using PX4 firmware on a 500mm quadcopter. The problem is it will only run a programmed mission once. I need to unplug the battery to get it to run the same mission again. This is something new since a recent firmware update. Is there a setting that would create this problem?
Rick
Can you provide a log from this test?
As far as I know, the mission should execute once again if u trigger mission after its finsihed
Yes it should but it doesn’t. Any helpful input?
Can you click on the first mission item in QGC and then go back to mission mode? That should start it from 0.
No. I am using a radio control ground station, not a computer. I use the computer to program and adjust the flight characteristics.
Well, then it’s not possible I’m afraid.
