QGC 4.2.3, Windows 10 Pro 21H2
Application settings specify Map provider/type Bing/hybrid
Offline maps → delete default tile set to delete the current tile set
Offline Maps → Add tile set → select Google Hybrid from new tile set dialog map type dropdown box → click download to generate tile set
Offline maps → export → select all → export to export the tile set
Offline maps → Import → replace existing set → import to import the previously generated tile set
Click on imported tile set to view tile set description and map type displays as (Bing hybrid) instead of the selected Google hybrid map type.
This happens occasionally.
I cannot identify any pattern as to why the map type is Bing hybrid instead of the selected Google hybrid. Cannot determine if the tile set was actually generated as Bing hybrid or Google hybrid.
I can supply a set of screen shots detailing the issue as well as the generated tile set.
