make px4_sitl jmavsim
-- PX4_GIT_TAG: v1.16.0-beta1-133-g03c7e7aa08
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.9.6", minimum required is "3")
-- PX4 config file: /Users/abc/Documents/xyz/qt/Firmware/boards/px4/sitl/default.px4board
-- PLATFORM posix
-- ROMFSROOT px4fmu_common
-- TESTING y
-- ETHERNET y
-- ROOT_PATH .
-- PARAM_FILE /fs/mtd_params
-- PX4 config: px4_sitl_default
-- PX4 platform: posix
-- PX4 lockstep: enabled
-- The CXX compiler identification is AppleClang 15.0.0.15000309
-- The C compiler identification is AppleClang 15.0.0.15000309
-- The ASM compiler identification is Clang with GNU-like command-line
-- Found assembler: /Library/Developer/CommandLineTools/usr/bin/cc
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /Library/Developer/CommandLineTools/usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /Library/Developer/CommandLineTools/usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- cmake build type: RelWithDebInfo
-- Could NOT find gz-transport (missing: gz-transport_DIR)
-- Gazebo simulation bridge module disabled: missing dependencies
-- Could NOT find Protobuf (missing: Protobuf_LIBRARIES Protobuf_INCLUDE_DIR)
-- Could NOT find gz-sim (missing: gz-sim_DIR)
-- Could NOT find gz-sensors (missing: gz-sensors_DIR)
-- Could NOT find gz-plugin (missing: gz-plugin_DIR)
-- Found Java: /Users/abc/Library/Java/JavaVirtualMachines/ms-21.0.6/Contents/Home/bin/java (found version "21.0.6")
-- ROMFS: ROMFS/px4fmu_common
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/abc/Documents/xyz/qt/Firmware/build/px4_sitl_default
ninja: error: unknown target 'jmavsim'
jmavsim is no longer supported, please try Gazebo.
