Hi guys, I’m new to PX4 and am following the PX4 Development guide. I am using macOS Catalina. I have all the simulation prerequisites and am trying to run jMAVSim. I am trying to run “make posix_sitl_default jmavsim” in the terminal. I keep getting the issue (and sorry I don’t know how to format the code differently):
Makefile:493: *** “Make target posix_sitl_default not found. It either does not exist or posix_sitl_default cannot be the first argument. Use ‘/Library/Developer/CommandLineTools/usr/bin/make help|list_config_targets’ to get a list of all possible [configuration] targets.”. Stop.
I also tried running “make posix jmavsim”, which I saw someone say to do on this forum, but this is what I got:
– PX4 version: v1.11.0-rc1-126-gcfbf69f2a7
– PX4 config file: /Users/lucasmaley/Firmware/boards/px4/sitl/default.cmake
– PX4 config: px4_sitl_default
– PX4 platform: posix
– PX4 lockstep: enabled
– cmake build type: RelWithDebInfo
– The CXX compiler identification is AppleClang 11.0.3.11030032
– The C compiler identification is AppleClang 11.0.3.11030032
– The ASM compiler identification is Clang
– Found assembler: /Library/Developer/CommandLineTools/usr/bin/cc
– Check for working CXX compiler: /Library/Developer/CommandLineTools/usr/bin/c++ - skipped
– Check for working C compiler: /Library/Developer/CommandLineTools/usr/bin/cc - skipped
– Building for code coverage
– ccache enabled (export CCACHE_DISABLE=1 to disable)
– Found PythonInterp: /usr/local/bin/python3 (found suitable version “3.8.5”, minimum required is “3”)
– build type is RelWithDebInfo
– PX4 ECL: Very lightweight Estimation & Control Library v1.9.0-rc1-341-g5356077
– Configuring done
– Generating done
– Build files have been written to: /Users/lucasmaley/Firmware/build/px4_sitl_default
[0/734] git submodule src/drivers/gps/devices
[7/734] Generating uORB topic headers
FAILED: uORB/topics/uORBTopics.hpp uORB/topics/actuator_armed.h uORB/topics/actuator_controls.h uORB/topics/actuator_outputs.h uORB/topics/adc_report.h uORB/topics/airspeed.h uORB/topics/airspeed_validated.h uORB/topics/battery_status.h uORB/topics/camera_capture.h uORB/topics/camera_trigger.h uORB/topics/cellular_status.h uORB/topics/collision_constraints.h uORB/topics/collision_report.h uORB/topics/commander_state.h uORB/topics/cpuload.h uORB/topics/debug_array.h uORB/topics/debug_key_value.h uORB/topics/debug_value.h uORB/topics/debug_vect.h uORB/topics/differential_pressure.h uORB/topics/distance_sensor.h uORB/topics/ekf2_timestamps.h uORB/topics/ekf_gps_drift.h uORB/topics/ekf_gps_position.h uORB/topics/esc_report.h uORB/topics/esc_status.h uORB/topics/estimator_innovations.h uORB/topics/estimator_sensor_bias.h uORB/topics/estimator_status.h uORB/topics/follow_target.h uORB/topics/geofence_result.h uORB/topics/gps_dump.h uORB/topics/gps_inject_data.h uORB/topics/home_position.h uORB/topics/hover_thrust_estimate.h uORB/topics/input_rc.h uORB/topics/iridiumsbd_status.h uORB/topics/irlock_report.h uORB/topics/landing_gear.h uORB/topics/landing_target_innovations.h uORB/topics/landing_target_pose.h uORB/topics/led_control.h uORB/topics/log_message.h uORB/topics/logger_status.h uORB/topics/manual_control_setpoint.h uORB/topics/mavlink_log.h uORB/topics/mission.h uORB/topics/mission_result.h uORB/topics/mount_orientation.h uORB/topics/multirotor_motor_limits.h uORB/topics/obstacle_distance.h uORB/topics/offboard_control_mode.h uORB/topics/onboard_computer_status.h uORB/topics/optical_flow.h uORB/topics/orb_test.h uORB/topics/orb_test_large.h uORB/topics/orb_test_medium.h uORB/topics/orbit_status.h uORB/topics/parameter_update.h uORB/topics/ping.h uORB/topics/position_controller_landing_status.h uORB/topics/position_controller_status.h uORB/topics/position_setpoint.h uORB/topics/position_setpoint_triplet.h uORB/topics/power_button_state.h uORB/topics/power_monitor.h uORB/topics/pwm_input.h uORB/topics/px4io_status.h uORB/topics/qshell_req.h uORB/topics/qshell_retval.h uORB/topics/radio_status.h uORB/topics/rate_ctrl_status.h uORB/topics/rc_channels.h uORB/topics/rc_parameter_map.h uORB/topics/rpm.h uORB/topics/safety.h uORB/topics/satellite_info.h uORB/topics/sensor_accel.h uORB/topics/sensor_accel_fifo.h uORB/topics/sensor_baro.h uORB/topics/sensor_combined.h uORB/topics/sensor_correction.h uORB/topics/sensor_gyro.h uORB/topics/sensor_gyro_fifo.h uORB/topics/sensor_mag.h uORB/topics/sensor_preflight.h uORB/topics/sensor_selection.h uORB/topics/subsystem_info.h uORB/topics/system_power.h uORB/topics/task_stack_info.h uORB/topics/tecs_status.h uORB/topics/telemetry_status.h uORB/topics/test_motor.h uORB/topics/timesync.h uORB/topics/timesync_status.h uORB/topics/trajectory_bezier.h uORB/topics/trajectory_waypoint.h uORB/topics/transponder_report.h uORB/topics/tune_control.h uORB/topics/uavcan_parameter_request.h uORB/topics/uavcan_parameter_value.h uORB/topics/ulog_stream.h uORB/topics/ulog_stream_ack.h uORB/topics/vehicle_acceleration.h uORB/topics/vehicle_air_data.h uORB/topics/vehicle_angular_acceleration.h uORB/topics/vehicle_angular_velocity.h uORB/topics/vehicle_attitude.h uORB/topics/vehicle_attitude_setpoint.h uORB/topics/vehicle_command.h uORB/topics/vehicle_command_ack.h uORB/topics/vehicle_constraints.h uORB/topics/vehicle_control_mode.h uORB/topics/vehicle_global_position.h uORB/topics/vehicle_gps_position.h uORB/topics/vehicle_imu.h uORB/topics/vehicle_imu_status.h uORB/topics/vehicle_land_detected.h uORB/topics/vehicle_local_position.h uORB/topics/vehicle_local_position_setpoint.h uORB/topics/vehicle_magnetometer.h uORB/topics/vehicle_odometry.h uORB/topics/vehicle_rates_setpoint.h uORB/topics/vehicle_roi.h uORB/topics/vehicle_status.h uORB/topics/vehicle_status_flags.h uORB/topics/vehicle_trajectory_bezier.h uORB/topics/vehicle_trajectory_waypoint.h uORB/topics/vtol_vehicle_status.h uORB/topics/wheel_encoders.h uORB/topics/wind_estimate.h uORB/topics/yaw_estimator_status.h
cd /Users/lucasmaley/Firmware/msg && /usr/local/bin/python3 tools/px_generate_uorb_topic_files.py --headers -f actuator_armed.msg actuator_controls.msg actuator_outputs.msg adc_report.msg airspeed.msg airspeed_validated.msg battery_status.msg camera_capture.msg camera_trigger.msg cellular_status.msg collision_constraints.msg collision_report.msg commander_state.msg cpuload.msg debug_array.msg debug_key_value.msg debug_value.msg debug_vect.msg differential_pressure.msg distance_sensor.msg ekf2_timestamps.msg ekf_gps_drift.msg ekf_gps_position.msg esc_report.msg esc_status.msg estimator_innovations.msg estimator_sensor_bias.msg estimator_status.msg follow_target.msg geofence_result.msg gps_dump.msg gps_inject_data.msg home_position.msg hover_thrust_estimate.msg input_rc.msg iridiumsbd_status.msg irlock_report.msg landing_gear.msg landing_target_innovations.msg landing_target_pose.msg led_control.msg log_message.msg logger_status.msg manual_control_setpoint.msg mavlink_log.msg mission.msg mission_result.msg mount_orientation.msg multirotor_motor_limits.msg obstacle_distance.msg offboard_control_mode.msg onboard_computer_status.msg optical_flow.msg orb_test.msg orb_test_large.msg orb_test_medium.msg orbit_status.msg parameter_update.msg ping.msg position_controller_landing_status.msg position_controller_status.msg position_setpoint.msg position_setpoint_triplet.msg power_button_state.msg power_monitor.msg pwm_input.msg px4io_status.msg qshell_req.msg qshell_retval.msg radio_status.msg rate_ctrl_status.msg rc_channels.msg rc_parameter_map.msg rpm.msg safety.msg satellite_info.msg sensor_accel.msg sensor_accel_fifo.msg sensor_baro.msg sensor_combined.msg sensor_correction.msg sensor_gyro.msg sensor_gyro_fifo.msg sensor_mag.msg sensor_preflight.msg sensor_selection.msg subsystem_info.msg system_power.msg task_stack_info.msg tecs_status.msg telemetry_status.msg test_motor.msg timesync.msg timesync_status.msg trajectory_bezier.msg trajectory_waypoint.msg transponder_report.msg tune_control.msg uavcan_parameter_request.msg uavcan_parameter_value.msg ulog_stream.msg ulog_stream_ack.msg vehicle_acceleration.msg vehicle_air_data.msg vehicle_angular_acceleration.msg vehicle_angular_velocity.msg vehicle_attitude.msg vehicle_attitude_setpoint.msg vehicle_command.msg vehicle_command_ack.msg vehicle_constraints.msg vehicle_control_mode.msg vehicle_global_position.msg vehicle_gps_position.msg vehicle_imu.msg vehicle_imu_status.msg vehicle_land_detected.msg vehicle_local_position.msg vehicle_local_position_setpoint.msg vehicle_magnetometer.msg vehicle_odometry.msg vehicle_rates_setpoint.msg vehicle_roi.msg vehicle_status.msg vehicle_status_flags.msg vehicle_trajectory_bezier.msg vehicle_trajectory_waypoint.msg vtol_vehicle_status.msg wheel_encoders.msg wind_estimate.msg yaw_estimator_status.msg -i /Users/lucasmaley/Firmware/msg -o /Users/lucasmaley/Firmware/build/px4_sitl_default/uORB/topics -e templates/uorb -t /Users/lucasmaley/Firmware/build/px4_sitl_default/msg/tmp/headers -q
Failed to import genmsg: No module named ‘genmsg’
You may need to install it using:
pip3 install --user pyros-genmsg
[13/734] Generating git version header
make: *** [px4_sitl] Error 1
I tried running “pip3 install --user pyros-genmsg”, as that message says, but then it says I already have it.
I have spent a lot of time on forums looking for similar questions and answers but haven’t been able to figure this out.
Any help on this would be greatly appreciated. Please let me know if you need any more information. Thanks
