Hi.
Using OS X and follow the toolchain setup and trying to get the simulator to work as in tutorial on web page.
But the it always fails after generating build files with
Generating uORB topic headers FAILED:
Have tried different simulators but all fail at same point.
Many thanks for any ideas what can be wrong.
Christian
Full build log
make px4_fmu-v2
– PX4 version: v1.11.0-beta1-1134-gb02e209507
– PX4 config file: /Users/christian/Firmware/boards/px4/fmu-v2/default.cmake
– PX4 config: px4_fmu-v2_default
– PX4 platform: nuttx
– cmake build type: MinSizeRel
– The CXX compiler identification is GNU 7.3.1
– The C compiler identification is GNU 7.3.1
– Found assembler: /usr/local/bin/arm-none-eabi-gcc
– Check for working CXX compiler: /usr/local/bin/arm-none-eabi-g++
– Check for working CXX compiler: /usr/local/bin/arm-none-eabi-g++ - works
– Check for working C compiler: /usr/local/bin/arm-none-eabi-gcc
– Check for working C compiler: /usr/local/bin/arm-none-eabi-gcc - works
– Found PythonInterp: /opt/local/bin/python3 (found suitable version “3.7.7”, minimum required is “3”)
– build type is MinSizeRel
– PX4 ECL: Very lightweight Estimation & Control Library v1.9.0-rc1-244-g870ec38
– Building and including px4_io-v2_default
– ROMFS: px4fmu_common
– ROMFS: Adding rc.board_defaults
– ROMFS: Adding rc.board_sensors
– ROMFS: Adding rc.board_mavlink
– Found SVD:
– Configuring done
– Generating done
– Build files have been written to: /Users/christian/Firmware/build/px4_fmu-v2_default
[0/736] git submodule platforms/nuttx/NuttX/nuttx
[1/736] Generating uORB topic headers
FAILED: uORB/topics/uORBTopics.hpp uORB/topics/actuator_armed.h uORB/topics/actuator_controls.h uORB/topics/actuator_outputs.h uORB/topics/adc_report.h uORB/topics/airspeed.h uORB/topics/airspeed_validated.h uORB/topics/battery_status.h uORB/topics/camera_capture.h uORB/topics/camera_trigger.h uORB/topics/cellular_status.h uORB/topics/collision_constraints.h uORB/topics/collision_report.h uORB/topics/commander_state.h uORB/topics/cpuload.h uORB/topics/debug_array.h uORB/topics/debug_key_value.h uORB/topics/debug_value.h uORB/topics/debug_vect.h uORB/topics/differential_pressure.h uORB/topics/distance_sensor.h uORB/topics/ekf2_timestamps.h uORB/topics/ekf_gps_drift.h uORB/topics/ekf_gps_position.h uORB/topics/esc_report.h uORB/topics/esc_status.h uORB/topics/estimator_innovations.h uORB/topics/estimator_sensor_bias.h uORB/topics/estimator_status.h uORB/topics/follow_target.h uORB/topics/geofence_result.h uORB/topics/gps_dump.h uORB/topics/gps_inject_data.h uORB/topics/home_position.h uORB/topics/hover_thrust_estimate.h uORB/topics/input_rc.h uORB/topics/iridiumsbd_status.h uORB/topics/irlock_report.h uORB/topics/landing_gear.h uORB/topics/landing_target_innovations.h uORB/topics/landing_target_pose.h uORB/topics/led_control.h uORB/topics/log_message.h uORB/topics/logger_status.h uORB/topics/manual_control_setpoint.h uORB/topics/mavlink_log.h uORB/topics/mission.h uORB/topics/mission_result.h uORB/topics/mount_orientation.h uORB/topics/multirotor_motor_limits.h uORB/topics/obstacle_distance.h uORB/topics/offboard_control_mode.h uORB/topics/onboard_computer_status.h uORB/topics/optical_flow.h uORB/topics/orb_test.h uORB/topics/orb_test_large.h uORB/topics/orb_test_medium.h uORB/topics/orbit_status.h uORB/topics/parameter_update.h uORB/topics/ping.h uORB/topics/position_controller_landing_status.h uORB/topics/position_controller_status.h uORB/topics/position_setpoint.h uORB/topics/position_setpoint_triplet.h uORB/topics/power_button_state.h uORB/topics/power_monitor.h uORB/topics/pwm_input.h uORB/topics/qshell_req.h uORB/topics/qshell_retval.h uORB/topics/radio_status.h uORB/topics/rate_ctrl_status.h uORB/topics/rc_channels.h uORB/topics/rc_parameter_map.h uORB/topics/rpm.h uORB/topics/safety.h uORB/topics/satellite_info.h uORB/topics/sensor_accel.h uORB/topics/sensor_accel_fifo.h uORB/topics/sensor_accel_integrated.h uORB/topics/sensor_accel_status.h uORB/topics/sensor_baro.h uORB/topics/sensor_combined.h uORB/topics/sensor_correction.h uORB/topics/sensor_gyro.h uORB/topics/sensor_gyro_fifo.h uORB/topics/sensor_gyro_integrated.h uORB/topics/sensor_gyro_status.h uORB/topics/sensor_mag.h uORB/topics/sensor_preflight.h uORB/topics/sensor_selection.h uORB/topics/servorail_status.h uORB/topics/subsystem_info.h uORB/topics/system_power.h uORB/topics/task_stack_info.h uORB/topics/tecs_status.h uORB/topics/telemetry_status.h uORB/topics/test_motor.h uORB/topics/timesync.h uORB/topics/timesync_status.h uORB/topics/trajectory_bezier.h uORB/topics/trajectory_waypoint.h uORB/topics/transponder_report.h uORB/topics/tune_control.h uORB/topics/uavcan_parameter_request.h uORB/topics/uavcan_parameter_value.h uORB/topics/ulog_stream.h uORB/topics/ulog_stream_ack.h uORB/topics/vehicle_acceleration.h uORB/topics/vehicle_air_data.h uORB/topics/vehicle_angular_acceleration.h uORB/topics/vehicle_angular_velocity.h uORB/topics/vehicle_attitude.h uORB/topics/vehicle_attitude_setpoint.h uORB/topics/vehicle_command.h uORB/topics/vehicle_command_ack.h uORB/topics/vehicle_constraints.h uORB/topics/vehicle_control_mode.h uORB/topics/vehicle_global_position.h uORB/topics/vehicle_gps_position.h uORB/topics/vehicle_imu.h uORB/topics/vehicle_land_detected.h uORB/topics/vehicle_local_position.h uORB/topics/vehicle_local_position_setpoint.h uORB/topics/vehicle_magnetometer.h uORB/topics/vehicle_odometry.h uORB/topics/vehicle_rates_setpoint.h uORB/topics/vehicle_roi.h uORB/topics/vehicle_status.h uORB/topics/vehicle_status_flags.h uORB/topics/vehicle_trajectory_bezier.h uORB/topics/vehicle_trajectory_waypoint.h uORB/topics/vtol_vehicle_status.h uORB/topics/wheel_encoders.h uORB/topics/wind_estimate.h uORB/topics/yaw_estimator_status.h
cd /Users/christian/Firmware/msg && /opt/local/bin/python3 tools/px_generate_uorb_topic_files.py --headers -f actuator_armed.msg actuator_controls.msg actuator_outputs.msg adc_report.msg airspeed.msg airspeed_validated.msg battery_status.msg camera_capture.msg camera_trigger.msg cellular_status.msg collision_constraints.msg collision_report.msg commander_state.msg cpuload.msg debug_array.msg debug_key_value.msg debug_value.msg debug_vect.msg differential_pressure.msg distance_sensor.msg ekf2_timestamps.msg ekf_gps_drift.msg ekf_gps_position.msg esc_report.msg esc_status.msg estimator_innovations.msg estimator_sensor_bias.msg estimator_status.msg follow_target.msg geofence_result.msg gps_dump.msg gps_inject_data.msg home_position.msg hover_thrust_estimate.msg input_rc.msg iridiumsbd_status.msg irlock_report.msg landing_gear.msg landing_target_innovations.msg landing_target_pose.msg led_control.msg log_message.msg logger_status.msg manual_control_setpoint.msg mavlink_log.msg mission.msg mission_result.msg mount_orientation.msg multirotor_motor_limits.msg obstacle_distance.msg offboard_control_mode.msg onboard_computer_status.msg optical_flow.msg orb_test.msg orb_test_large.msg orb_test_medium.msg orbit_status.msg parameter_update.msg ping.msg position_controller_landing_status.msg position_controller_status.msg position_setpoint.msg position_setpoint_triplet.msg power_button_state.msg power_monitor.msg pwm_input.msg qshell_req.msg qshell_retval.msg radio_status.msg rate_ctrl_status.msg rc_channels.msg rc_parameter_map.msg rpm.msg safety.msg satellite_info.msg sensor_accel.msg sensor_accel_fifo.msg sensor_accel_integrated.msg sensor_accel_status.msg sensor_baro.msg sensor_combined.msg sensor_correction.msg sensor_gyro.msg sensor_gyro_fifo.msg sensor_gyro_integrated.msg sensor_gyro_status.msg sensor_mag.msg sensor_preflight.msg sensor_selection.msg servorail_status.msg subsystem_info.msg system_power.msg task_stack_info.msg tecs_status.msg telemetry_status.msg test_motor.msg timesync.msg timesync_status.msg trajectory_bezier.msg trajectory_waypoint.msg transponder_report.msg tune_control.msg uavcan_parameter_request.msg uavcan_parameter_value.msg ulog_stream.msg ulog_stream_ack.msg vehicle_acceleration.msg vehicle_air_data.msg vehicle_angular_acceleration.msg vehicle_angular_velocity.msg vehicle_attitude.msg vehicle_attitude_setpoint.msg vehicle_command.msg vehicle_command_ack.msg vehicle_constraints.msg vehicle_control_mode.msg vehicle_global_position.msg vehicle_gps_position.msg vehicle_imu.msg vehicle_land_detected.msg vehicle_local_position.msg vehicle_local_position_setpoint.msg vehicle_magnetometer.msg vehicle_odometry.msg vehicle_rates_setpoint.msg vehicle_roi.msg vehicle_status.msg vehicle_status_flags.msg vehicle_trajectory_bezier.msg vehicle_trajectory_waypoint.msg vtol_vehicle_status.msg wheel_encoders.msg wind_estimate.msg yaw_estimator_status.msg -i /Users/christian/Firmware/msg -o /Users/christian/Firmware/build/px4_fmu-v2_default/uORB/topics -e templates/uorb -t /Users/christian/Firmware/build/px4_fmu-v2_default/msg/tmp/headers -q --constrained-flash
File “tools/px_generate_uorb_topic_files.py”, line 46, in
from packaging import version
ModuleNotFoundError: No module named ‘packaging’
[8/736] Generating mixer_multirotor.generated.h
make: *** [px4_fmu-v2] Error 1
