Hello guys and girls, my first post here. I’m hoping you can help me out.
I have a pixhawk 1 with Lidar Lite v3. I have multiple Lidar sensors of which I can choose which to use (say lidar A, B and C). Now here’s the thing:
When I connect Lidar B or C (so connect 5V etc.), and connect to qGroundcontrol, there is no readings under Analyze–>Distance_sensor.current_distance.
When I connect lidar A, and turn on qGroundcontrol, I get correct readings under Analyze–>Distance_sensor.current_distance. If I then leave everything on and connected, but switch lidar A for lidar B or C, I get correct readings.
Once again if I reboot with lidar B or C I will get no readings.
The problem should be clear in the video below:
Does anybody have similar experiences or any explanations for this?
It seems the lidar is working but does not work after a reboot.
With kind regards,
Lars
