JSBSim-bridge mavlink interface hil_mode
Hi, recently, I tried to create new aircraft in jsbsim and run the SITL with PX4-Autopilot.
It could run well when I ran the JSBSim separately with the new aircraft XML.
But, When I ran with PX4 using new aircraft XML, It couldn’t run.
So, I printed the variables to do debug.
Then, I knew that the hil_mode_ variable was not false, when I ran SITL.
I fixed this problem by make it false in jsbsim_bridge/include/mavlink_interface.h.
Can I edit the code like this??? and, when the jsbsim_bridge runs, what source code declares the hil_mode variable’s value???
I edited the code temporarily, but I want to validate and check with the community.
@Jaeyoung-Lim Do you have any idea?
@JeongseokHyun You should make a PR in the repository, and I can have a look
@JeongseokHyun was this ever resolved? I ran into the same error when using a custom airframe. When running in SITL mode, the hil_mode_ variable was incorrectly set to true and the build stalled on trying to make a UDP connection when it should have only been making a TCP connection.
