Hi, we are looking for external pilots with some specific skill sets to work in Woodbridge, Ontario, Canada . I feel like this would be a great spot to post it and find qualified individuals. I have attached a detailed description below, so reach out to me (josh.m@skyx.com) if you are interested. Thank you.
Summary
SkyX Systems wishes to contract a drone service provider to have RPAS pilots available on an as-needed
basis. The RPAS Pilot-In-Command (PIC) and Second-In-Command (SIC) will be responsible for the safe
operation of SkyOne on a flexible basis to accommodate SkyX’s flight testing and demonstration schedule.
SkyOne is a small (under 25 kg) fixed wing VTOL RPAS.
The PIC will remotely pilot the RPAS using SkyX’s proprietary SkyXOS command and control software
and will typically operate out of the SkyX office in Woodbridge, ON. The SIC will typically operate at one
of SkyX’s test sites in the areas surrounding the Greater Toronto Area (GTA) to setup the test site, provide
situational awareness to the PIC, and act as a safety pilot to manually operate the aircraft using a Radio
Control (RC) transmitter where required. SICs would be accompanied by one or more members of the
SkyX Flight Operations team.
Testing and customer demonstration flights may be required at other locations in Canada, the United
States, or other locations around the world. Where extensive travel is required beyond normal operations
around the GTA, SkyX will arrange for travel accommodations and provide a per-diem. The RPAS Pilots
are expected to demonstrate a professional demeanor while on-site and maintain high standards for
operational excellence and aviation flight safety.
It is the intention of SkyX to establish an ongoing service agreement to provide RPAS pilots who will be
trained on our system and available on an as-needed basis. SkyX will provide training for the safe
operation of SkyOne during all operating conditions. The initial scope of this service would be to have a
PIC and an SIC available for normal flight test activities with 1-2 days’ notice. This may require up to two
(2) PICs and two (2) SICs to be trained and certified on SkyX’s system.
SkyX Position Title
RPAS Pilot-in-Command / RPAS Second-In-Command
Reports To
Normal Operating Conditions
• Typically 1-3 flight days per week, 6-10 hours per day
• 1-2 days’ notice for local test flights and demonstrations
• 10+ days’ notice for flights and demonstrations requiring travel outside the normal test sites
• Weekend and evening work may be required
• Travel may be required to other locations in Canada, the United States, or other locations
• Occupational hazards associated with RPAS flights and equipment
Responsibilities – Pilot in Command
• Remotely pilot the RPAS using SkyX’s proprietary SkyXOS command and control software from the office in Woodbridge, or on site using the portable SkyGCS as required
• Conduct site-specific assessments prior to flight, including reviewing aviation weather reports, and coordinating with airspace authorities and other organizations as required.
• Plan flights (select routes, altitudes, and airspeeds) to ensure that the required test objective is met while following company policies and Transport Canada regulations
• Coordinate with the SIC to complete preflight checks according to SkyX SOPs
• Monitor the in-flight telemetry of aircraft systems during all phases of flight
• Where necessary, order any changes to the flightpath or discontinue the use of automation and transfer control of the aircraft to the SIC
• Maintain detailed flight records and report any maintenance issues
• Follow any other SkyX policies and procedures as defined in our SOPs
• Other duties as assigned
Responsibilities – Second in Command
• Act as an on-site safety pilot who provides the PIC with situational awareness and visual observation of the flight area
• Perform an on-site setup and inspection to ensure that the operational area is safe for flight
• Assemble and inspect SkyOne aircraft before flight to verify that controls, instruments, and all other systems are functioning properly
• Coordinate with the PIC to complete preflight checks according to SkyX SOPs
• Where necessary, order any changes to the flightpath or discontinue the use of automation and assume vehicle control from the PIC using an RC Transmitter
• Report any maintenance issues or abnormal occurrences to the PIC
• Other duties as assigned.
Qualifications
• Minimum three years of flying experience with RPAS. Preference would be given to operators with experience using PX4/ArduPilot systems, or manual RC aircraft.
• Transport Canada Small RPAS Pilot Certificate – Basic Operations. Preference would be given to holders of an Advanced Operations certificate, a Flight Reviewer rating, or an FAA Part 107 certificate.
• Must be medically fit to perform flight duties
• Vision correctable to 20/20
• Fluent in English (written and spoken)
• Sound judgement and reasoning
• Works well under pressure
• Professionalism and a demonstrated ability to provide excellent customer service
