jMAVsim bug in macOS 10.15.5
Hi, I encountered a bug trying to run jMAVsim after launching this command:
make px4_sitl jmavsim
It shows a lot of stuff in the terminal, then it launches the application, but it crashes and I see this in the terminal:
2020-06-08 21:42:01.249 java[12368:66275] Apple AWT Internal Exception: NSWindow drag    Preformatted text regions should only be invalidated on the Main Thread!
2020-06-08 21:42:01.249 java[12368:66275] *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'NSWindow drag regions should only be invalidated on the Main Thread!'
*** First throw call stack:
	0   CoreFoundation                      0x00007fff33806be7 __exceptionPreprocess + 250
	1   libobjc.A.dylib                     0x00007fff6c5de5bf objc_exception_throw + 48
	2   CoreFoundation                      0x00007fff3382f3dc -[NSException raise] + 9
	3   AppKit                              0x00007fff30a2dddc -[NSWindow(NSWindow_Theme) _postWindowNeedsToResetDragMarginsUnlessPostingDisabled] + 310
	4   AppKit                              0x00007fff30a15842 -[NSWindow _initContent:styleMask:backing:defer:contentView:] + 1416
	5   AppKit                              0x00007fff30a152b3 -[NSWindow initWithContentRect:styleMask:backing:defer:] + 42
	6   libnativewindow_macosx.jnilib       0x000000014f04df6e Java_jogamp_nativewindow_macosx_OSXUtil_CreateNSWindow0 + 398
	7   ???                                 0x0000000113c8a407 0x0 + 4626883591
libc++abi.dylib: terminating with uncaught exception of type NSException
/Users/lannimatteolorenzo/Firmware/Tools/jmavsim_run.sh: line 80: 12368 Abort trap: 6           java -XX:GCTimeRatio=20 -Djava.ext.dirs= -Djavax.accessibility.assistive_technologies=" " -jar jmavsim_run.jar $device $extra_args
I’m using a MacBook Pro 13" late 2016 with macOS Catalina 10.15.5.
Any idea if I can solve this? Thank you.
Can you try out this pull request?
So you would do:
cd Tools/jMAVSim
git fetch
git checkout pr-update-libs
git submodule update
cd ../..
And then build and not agree to update the submodule but leave them as is.
Again, you helped me a lot :slight_smile: it solved the problem, now I can launch the jmavsim simulation successfully, thank you.
There is another problem I face with Gazebo instead, it seems to me like a typing error in the code but I’m not good enough to solve it myself.
Do you think I can point it out in this topic?
So you’re saying this pull request fixes it? If so that’s good feedback and means we should probably merge it.
Please create a new thread.
Yes exactly, at least for me it worked immediately just following your instructions.
Ok I’ll create a new thread about Gazebo :slight_smile:
