i am facing the same issue here. Sometimes it keeps staying at ‘waiting for simulator’ stage:
[2/2] cd /home/caomuqing/iot_px4/build_posix_sitl_default/tmp && /home/caomuqing/iot_px4/Tools/sitl_r.../init/ekf2 none jmavsim iris /home/caomuqing/iot_px4 /home/caomuqing/iot_px4/build_posix_sitl_default
args: /home/caomuqing/iot_px4/build_posix_sitl_default/src/firmware/posix/px4 posix-configs/SITL/init/ekf2 none jmavsim iris /home/caomuqing/iot_px4 /home/caomuqing/iot_px4/build_posix_sitl_default
SITL ARGS
sitl_bin: /home/caomuqing/iot_px4/build_posix_sitl_default/src/firmware/posix/px4
rcS_dir: posix-configs/SITL/init/ekf2
debugger: none
program: jmavsim
model: iris
src_path: /home/caomuqing/iot_px4
build_path: /home/caomuqing/iot_px4/build_posix_sitl_default
SITL COMMAND: /home/caomuqing/iot_px4/build_posix_sitl_default/src/firmware/posix/px4 /home/caomuqing/iot_px4 /home/caomuqing/iot_px4/posix-configs/SITL/init/ekf2/iris
data path: /home/caomuqing/iot_px4
commands file: /home/caomuqing/iot_px4/posix-configs/SITL/init/ekf2/iris
______ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
0 WARNING: setRealtimeSched failed (not run as root?)
/home/caomuqing/iot_px4/Tools/jmavsim_run.sh: line 44: ant: command not found
/home/caomuqing/iot_px4/Tools/jmavsim_run.sh: line 45: cd: out/production: No such file or directory
Error: Unable to access jarfile jmavsim_run.jar
INFO [dataman] Unknown restart, data manager file 'rootfs/fs/microsd/dataman' size is 11405140 bytes
INFO [platforms__posix__drivers__ledsim] LED::init
INFO [simulator] Waiting for initial data on UDP port 14560. Please start the flight simulator to proceed..
But sometimes it show the Error: Unable to access jarful jmavsim_run.jar, after the ‘waiting for simulator’ message:
______ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
18446744073709551615 WARNING: setRealtimeSched failed (not run as root?)
