Is it possible to extract telemetry from QGroundControl in real time?
I would like to use QGroundControl with Rosetta Drone to get streams and telemetry (Location, gyro angles etc) and send them to my server in real time .
I know, that, I could see these data with MAVLink Inspector.
Is it possible to somehow extract these data in real time? Maybe this app could be used as a MAVLink relay?
What I want to achieve:
DJI DroneRosetta appQGroundControlmy own, custom app
I am new to dealing with, so I may miss something.
I use a library for python (i think theres’s one similar in C) called pymavlink. The library cathces the MavLink messeges between QGC and your drone. I use a PX4, but should be the same for your drone. To use this library you have to enable in your QGC something called MavLink Fowarding.
I read about something called MAVSK, i haven’t used it yet . Maybe is better this one idk.
Hope this was usefull
Thank you this is exactly what I needed
I only needed to check where to turn it on MAVLink · QGroundControl User Guide
And to write simple test script:
from pymavlink import mavutil
# Set up connection to vehicle
master = mavutil.mavlink_connection('udp:localhost:14550')
# Wait for the heartbeat message to ensure connection
master.wait_heartbeat()
# Get list of available MAVLink messages
msg_names = master.messages.keys()
# Print out list of available messages
print("Available MAVLink messages:")
for name in msg_names:
    print("- {}".format(name))
I’m dealing with a similar issue guys, i wanted to build my own web based control station ui, is it possible to send these received data across the web?
i.e : Dynamic drone telemetry data → received from QgroundControl → sent to my python server → displayed on my web ui
