How to set custom_mode in HEARTBEAT
I want to know how to set the base_mode and custom_mode in HEARTBEAT.
HEARTBEAT (0)
Field Name
base_mode,
custom_mode
I am working on a vehicle side and using Server plugins. I have the following process:
QGC -> Send "Takeoff" command -> Vehicle take off
QGC <- Send "Custom_mode" with "AUTO:TAKEOFF" <- Vehicle
QGC show "AUTO:TAKEOFF"
But set_custom_mode() is private API in MAVSDK
void ServerComponentImpl::send_heartbeat()
mavlink_address.component_id == MAV_COMP_ID_AUTOPILOT1 ? _base_mode.load() : 0,
mavlink_address.component_id == MAV_COMP_ID_AUTOPILOT1 ? _custom_mode.load() : 0,
class ActionServerImpl : public ServerPluginImplBase {
private:
void set_base_mode(uint8_t base_mode);
void set_custom_mode(uint32_t custom_mode);
And I tried “mavlink_msg_set_mode_pack_chan()” to send the message but it doesn’t work.
So I modified the MAVSDK in action_server.cpp
void ActionServer::set_base_mode(uint8_t base_mode) const
_impl->set_base_mode(base_mode);
void ActionServer::set_custom_mode(uint32_t custom_mode) const
_impl->set_custom_mode(custom_mode);
Additionally, set_system_status() and add_capablilities() also have the same problem, so I modified them as follows.
Sever_component.cpp
void ServerComponent::set_system_status(uint8_t system_status)
_impl->set_system_status(system_status);
void ServerComponent::add_capablilities(uint64_t capablilities)
if (_impl) {
_impl->add_capabilities(capablilities);
I want to use MAVSDK without modifying it. I want to know if there is another way.
