Hi!
I have some troubles getting any information (but for simplicity start with a heartbeat) from my companion computer.
The situation is as follows, I have a drone, with cube flight controller. Then I have a companion computer connected to the flight controller via UDP.
On my companion computer using Mavsdk:
- I can find the system having the auto pilot (flight controller)
- My companion computer is sending heartbeats (sys id 0, component id 192)
mavsdk::Mavsdk mavsdk;
mavsdk::Mavsdk::Configuration config(mavsdk::Mavsdk::Configuration::UsageType::CompanionComputer);
config.set_system_id(1);
config.set_component_id(MAV_COMP_ID_ONBOARD_COMPUTER2);
config.set_always_send_heartbeats(true);
mavsdk.set_configuration(config);
mavsdk::ConnectionResult connection_result =
mavsdk.add_any_connection(connection_string, mavsdk::ForwardingOption::ForwardingOn);
std::shared_ptr<mavsdk::System> get_system(mavsdk::Mavsdk& mavsdk) {
for (auto system : mavsdk.systems()) {
if (system->get_system_id() == 1) // system_id 1 = autopilot (cube)
return system;
ROS_ERROR("No autopilot found");
return {};
Then I have a simple little program that makes the same connection and reads out heartbeats. I would expect:
- That my companion computer (component id 192) would be shown as added component
- That I would see the heartbeat
But I don’t and I cannot figure out why. Does someone have some ideas on how to establish this?
