Thanks for confirming.
Since you specifically need satellite imagery, I would separate the problem into two parts:
1. Obtaining imagery with appropriate offline rights
For approximately 60 GB of coverage, I would look for a source that explicitly supports bulk downloads and offline use, rather than trying to extend QGC’s Bing tile downloader.
One possible source is Copernicus Sentinel-2 imagery, which is available for download, although its spatial resolution (typically 10 m for the highest-resolution bands) is substantially lower than detailed commercial satellite basemaps.
If you need higher-resolution imagery, you may need a provider offering an appropriate offline imagery licence.
2. Making the imagery usable in QGroundControl
This is a separate technical question.
Downloading GeoTIFFs or another geospatial imagery format does not automatically make them compatible with QGC’s existing offline map cache.
The imagery may require tiling, georeferencing and an appropriate map-provider integration. I would verify the supported import or integration workflow for your specific QGC version before downloading a large dataset.
For now, I would avoid modifying QGC’s Bing download limits.
One final detail would help narrow this down: what ground resolution do you need?
For example, is 10 m/pixel sufficient for regional flight planning, or do you need approximately 0.5–1 m/pixel to identify roads, buildings and smaller ground features?
That determines which satellite imagery sources are realistically suitable.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
